    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 68
    Thread: Tremec TKX
    1. #21
      Oct 2018
      Phoenix, AZ
      Ok I have inside info from 2 individuals sent preproduction units for testing. I am a current TKO600 owner for reference. I have hated shifting my TKO from almost the beginning. Any shift over 5000 rpm is TERRIBLE and it is just clunky feeling at any RPM. I was spoiled having driven many cars running various versions of the T56 and regretted not going that route with my project.
      What I was told is that the TKO design is in the same family as the old top loaders. So no matter what you upgrade, it is still going to have clear limitations. The TKX brings in the significantly more modern internals of the Magnum trio. Larger gear sets, cone synchros, better shift forks, etc. These are NOT the same in any way aside from the ability to bolt-in the TKX where a TKO was before.
      Of these two individuals, one has driven with the trans. He said the shifting at any RPM is night and day improved from the TKO twins and shifting above 6000rpm isn't even a fair comparison because the TKX blows the TKO away.
      So as a TKO owner, I was looking at faceplated gearsets to try and somehow improve this thing when racing, but the price of the TKX makes that really not worth it in my case. I'll be eventually selling my TKO to swap to the TKX. The TKO is still great for a hot rod, but if you are road racing like I am....no way. Tremec intends to just phase out the TKO twins and the TKX will fill that "void" moving forward.
      I do not believe the T56 is at risk of being replaced. It still very much serves a purpose to have 6 gears and the larger power rating. The TKX simply gives a long overdue 5 gear option that will work with modern demands in tight spaces. Tremec will continue to dominate the manual swap realm for a long time to come by making this move. I applaud them.
    2. #22
      Great post, Shaun!
    3. #23
      Jul 2013
      N. Scottsdale
      If it fits an A body with no cutting and shifts like a T56, I’ll put one in my ‘67 GTO for sure.
    4. #24
      Feb 2007
      Tinley Park, IL
      This will be a good option whenever my Keisler RS-600 bites the dust...
      Nick ~
      1969 Cutlass
    5. #25
      Red Deer, Alberta, Canada
      I want to put one behind 1000rwhp and see if it lives, seriously interested.
      Matt
      Instagram: Cst_koon
    6. #26
      Quote Originally Posted by protour_chevelle View Post
      Depends on how much traction you get...lol
    7. #27
      NJ
      Anybody know if a shifter from a TKO 600 will fit it. I have a nice Mcleod shifter in my 70 Camaro that sits perfectly in my console. Would be nice to keep it. I saw this trans, and I am really thinking about it, even with my trans upgraded by Rockland Standard Gear it still isn't that great. I am planing to raise my trans up to get some of the driveline angles better, I won't cut the tunnel, interior and everything is done so this is a good even though expensive option. Hopefully we can get some good info on how much smaller the top of the case is.
    8. #28
      Chicago suburbs
      Hoping to get another .5 or more deg out of this too with the driveline with the smaller case. Not sure about the shifter though.
    9. #29
      Jun 2010
      Deployed
      Where did you get the info that the gear set is bigger? The video released from
      Bowler Transmission says other than 3rd gear the gear sets are identical???
      I don’t think anyone assumes Tremec would still produce the TKO. It’s a generation change...the 3550 is gone..the TKO II is gone, it makes sense for the TKO to go as well.
      1970 Camaro/DSE build
    10. #30
      lindenhurst ny
      I just ordered tkx close ratio for my 87 monte carlo ss aerocoupe. They are taking orders, 2 months out.
      Rob
      87 monte carlo ss aerocoupe under the knife
      https://www.pro-touring.com/showthre...8-87-aerocoupe
    11. #31
      lindenhurst ny
      Rob
    12. #32
      Hildebran, NC
      Third gear size comparison is in this video. At about 1:29.
      https://www.youtube.com/watch?v=NUDDYWDi7yY
    13. #33
      Jun 2010
      Deployed
      Quote Originally Posted by rchaskin View Post
      Yes...Just 3rd gear. Which is also an upgrade you can do to your TKO....
    14. #34
      Chicago suburbs
      I ordered mine too.
      You can't "upgrade" a TKO to become a TKX.
      This thread was started to concentrate on any info that anyone has about the TKX. I think it's very clear that a TKO is not a TKX. Some similarities? Sure, but not the same.
    15. #35
      Just North of NYC
      I don’t believe there is even one part that is shared between them and badassz28 is saying they’re the same trans. Lol
      I have one of the first tko600s- when i ordered it they weren’t shipping yet, just like the tkx now. I’ve heard they made some engineering changes fairly early that mine doesn’t have. Mine is notchy as hell, 3rd has some whine, it seeps from somewhere, and it won’t let me shift over 5500 or so. I had to perform a craniotomy on my 1969 Mustang tunnel to get it to fit. Other than that it’s fine.
      All kidding aside it’s lived behind 500ft lbs for 15 years and numerous roadrace and 1/4 mile track days so it’s hard to complain about it’s durability, but from day one it was never snick snick.
      I’m hoping I can use my same bell and aluminum driveshaft. Can anyone confirm?
    16. #36
      Chicago suburbs
      From what I've heard from Tremec and others it's a direct swap.
    17. #37
      Feb 2016
      Lawrenceville, IL
      Here is more technical info on the new TKX.
      - - - Updated - - -
      Quote Originally Posted by another69 View Post
      That is true, we did the swap here in house from a TKO to our test TKX, no other changes needed.
      visit us on the web at www.bowlertransmissions.com
    18. #38
      Sep 2018
      Knoxville, TN
      Quote Originally Posted by Alponcho View Post
      Mine is an auto, for the longest time I was going to go 2004R. But the mod to the floor was supposed to be minimal for the TKO, so I had been leaning that way. Got a quote a while back. This seals it for me, though. Trying to figure out which vendor to use right now.
      67 GTO - Build underway
      66 Bronco U13 Roadster
      And a couple of 80's Porsches
    19. #39
      Oct 2010
      Rockaway. NJ
      So I am now really considering this..... The fact that I do not have to cut my floor..... plus one other thing I should have realized.... but did not until today......
      My GTO has 3.36 rear gears..... and I always felt the .68 overdrive was too much for my gearing and I would have to swap in taller gears to keep from lugging engine around town or even slower highway speeds and the .82 was just not enough to warrant the money for the swap.....
      Stupid me..... The version of the TKO/TKX with the 3.27 first gear and the .72 overdrive is like perfectly geared for cars like mine..... More fun around town and overdrive that works with my rear gearing.....
      Am I wrong?
      Troy
      67GTO
    20. #40
      Troy,
      You're not wrong.
