    Results 1 to 10 of 10
      64 Nova 5.3 LSA blower and AC questions
      Preparing to install a LSA supercharger on my gen 3, 5.3 64 Nova. I will also be installing Vintage air later this winter. My current setup doesn't overheat with a cheap Champion ebay radiator here in Arizona.
      My concern is once the supercharger intercooler and the AC condenser are added in front of the radiator I may be asking for problems in the Arizona summers.
      The car is a manual so no trans cooler required. Also the LSA will be all stock so maybe 9psi and like 500 horse?
      My question is what radiator to run? I plan to drive this car hard, really hard. So while not looking to spend money unnecessarily, I am wanting a MAX effort radiator. Also curious about double pass radiators vs single pass, any thoughts?
      Thanks in advanceAttachment 201444Name:  20210910_014811[583]a.jpg
Size:  335.4 KBName:  20220813_142328[582].jpg
      Jacksonville, FL
      I would call C&R. I love the one in mine.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      X2.
      Dec 2008
      Champaign IL
      I have a C&R in my lsa powered 63 as well. I don’t have the part number handy but has the engine oil and power steering cooler as well. No heat problems so far, running a gt500 heat exchanger and vintage air.
      Brandon
      71 El Camino ZZ430/700r4,
      72 Buick Sun Coupe slowly working on LSx/6spd swap
      63 Nova husband and wife daily driver and autocross project
      Dec 2019
      I'm in AZ also and I have LT4 with vintage AC and 4L80E trans cooler. I have a C&R setup with dual SPAL brushless fans. Here is a video of the car https://youtu.be/zmfhky13DaU you can see my setup. I've had it out several times this summer and it usually runs between 195 and 210 max.
      Dec 2019
      Oh, PS - I have the factory blower from the LT4 I removed to install the Magnuson. I may be selling that. It's got 500 miles on it from GM crate motor
      Dec 2019
      I just remember I posted about my build, you can see my setup here https://www.pro-touring.com/threads/...hanger-it-fits!
      Thanks for the replies. Wow, everyone runs C&R? What exactly makes them so popular? They are certainly spendy
      C&R uses high quality Denso cores, at least they used to.
      Seems like a multi-tiered question to me. If if was me personally, if the champion radiator is working properly now just add the VA and intercooler and see what happens. You very well could have enough with your current setup to properly cool. If you have trouble keeping it all cool, I'd go with at least a dual pass radiator. I was running a Auto City Classic's dual pass LS swap radiator and retrofit C7 Brushless Spal fan. My coolant temps would hold at whatever temperature I set the fans to, and while driving I would see the temps drop to 185*. My IAT's would never get over 110*. But, that was in NY where the temps were around 80-85, so you may see different results in AZ summer.
      As for the LSA cooling, your best bet is to get the best intercooler that you can, increase the lines to 3/4" and get a good pump. CWA100 is a great performing pump at a good price. Keeping the IAT's down will help the supercharger live a good long life as well as more HP.
