      Oct 2007
      orange county, california
      69 Camaro, Driver side window moves around a LOT
      Hi Friends.
      I have a 69 Camaro and my drivers side window is able to move around A LOT.
      When the window is rolled all the way up, it stops a solid 1/4" from the sop, leaving a gap for air/water. I have to open the door and grab the window and lift it up the last 1/4". It will then sta in position.
      The passenger side window stays in position with no problem and does not move. It rolls up with no problems.
      Im looking to figure out what is causing this problem and how to fix it? Here is a video of the door moving in action. Thoughts? Ideas?
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Oct 2007
      Just a bump incase anyone has any ideas....?
      El Paso, Texas
      Pensacola, FL
      The roller on the the rear track looks to be non existent or in pieces. Front is likely the same. The rollers are replaceable I believe. Here's a link to help you see what the full assembly looks like
      https://www.npdlink.com/product/plat...lh/144260/8122
