    Thread: Dexron
      Jan 2020
      Dexron
      I have a GM 4L65E automatic transmission and I need to replace the pan gasket. I am not sure what fluid is in the transmission now and not planning on draining or flushing the torque converter. I would be filling the pan only.
      Which Dexron should I use (III or VI)?
      Apr 2012
      Woodstock, IL
      Quote Originally Posted by vaca828 View Post
      If you do not know... then use Dex VI. Write it on the pan so you know next time it’s serviced
      -Dale
      SchwartzPerformance
