      May 2008
      Baton Rouge, LA
      1969 Camaro Door Fuzzies
      I am in the process of installing my quarter glass and have everything fitting pretty well. I installed the reproduction door fuzzies and they fit so tight to the window that the power windows are struggling to go up and down.
      Is this normal? I know them fitting tight is a good thing but not sure things are gonna work as they fit now...
      Mountain Springs, Texas
      You can adjust your glass to space it a little further away from the fuzzies.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      May 2008
      Baton Rouge, LA
      Thanks Don. I have them adjusted more inward and that helped. I am using TMI door panels and it appears that fit is going to be tight as well. I will keep working it.
      I saw on your build thread that you are working on the quarter glass without the door glass installed. While not an expert I have always found that the door and quarter glass need to be aligned together to get a good seal everywhere including the seal between the door and quarter glass.
      Don
