    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 46
      Nov 2007
      Dayton, Ohio
      69 Mustang SuperCoupe
      I've been on these forums for a long time and have never made a build thread for my car, mostly because of the slow progress. Well I decided to create one to somewhat document the progress such that it is.
      Some background. This car is the 3rd (of 16)(2nd 69) mustang I've owned. I bought it in December 1983 when stationed at Blytheville AFB Arkansas. It changed hands a couple of times before I got it but had come from Texas with a young airman. It actually got the 351C engine from my 72 Gran Torino sport at one time. It had a 351W 3 spd in it by the time I got it. I drove it for a while even moving it when I transfered to Grissom AFB Indiana. Sometime around late 84/early 85 I traded my frozen 429 SCJ motor I had for the 72 Gran Torino Sport for a 70 351C with completed machine work and ready to build. I built the cleveland and swapped out the windsor replacing the 3 spd and 8 inch rear with a close ratio 4 spd and 9 inch with 3.00-1 gears from a 70 cougar at the same time about March 85. I drove it pretty regularly till mid October 86 when I decided to rebuild the car. It's been in various states of dis-assembly ever since.
      This past fall I contacted Ben on these forums and contracted him to do a rendering for my car as inspiration and to help motivate me to do more. I'm not getting any younger! This represents my vision for at least the exterior of my car.
      Condition when bought.
      In Indiana after engine rebuild
      At parents place spring 85
      Marti report
      I modeled the framing and interior layout in SolidWorks several years ago as I was redeveloping my plans for the car. Not 100% accurate but useful nonetheless.
      The rear frame rails from S&W Racecars tacked up
      Framing in process
      Rear bumper mounts
      New taillight panel & filler mod
      Right quarter panel cut out, new outer wheelhouse welded in. Old one trimmed 2 inches otbd of flange & new one mated to it with flange trimmed off.
      Fabbing right quarter scoop & ducting.
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
      Nov 2007
      Dayton, Ohio
      Front brake scoops
      Molds
      Lay-up
      Removed from molds
      Initial trim
      Initial test fit
      Final test fit. I haven't taken any pics of the finished scoops yet, will have to do that.
      Lower pan and front airdam 1st attempt
      I didn't take many pics of the progress so there was a lot of work involved between when I did take pics.
      Test fitup
      Worked on mounting brackets for the front brake cooling scoops.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Nov 2007
      Dayton, Ohio
      Gauge panel fabrication
      Mold
      Lay up
      Clean up & smoothing
      Primed
      Gauge holes going in
      Attaching to trimmed factory panel with JB Weld
      Sanded & primed
      Painted
      Finished & wired
      More to come as I find time to post.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Nov 2007
      Dayton, Ohio
      Lower dash mod
      I may tinker with it some more as I'm not 100% satisfied with it.
      My stainless steel gas tank. It has a sump area below the larger opening. The sump has openings on each side and covered with SS mesh. I've filled the tank with fuel cell foam blocks to minimize fuel sloshing. The bottom panels angle towards the sump at about a 20 degree angle.
      3D model
      I supplied the SS pieces and a friend Tig welded it for me.
      Using this fill valve
      Name:  ATL TF183A Fill Neck.jpg
      Lower mount for the 3-link lower arms. They mount to the axle leaf spring pads with the U-bolts.
      3D model
      Name:  lower link mount.jpg
      Welded up & lower arm attached
      Finished mount
      Rebuilt my pedal bracket & pedals. Installed a Mustangsteve bearing kit.
      Revisited the pedals, modified.
      The 9 inch rear is getting 3.50 gears replacing the 3.00 ones. I'm also going to try the Power Trax No-Slip set up for the differential. I have all new ARP hardware for it also.
      Name:  PowerTrax No-Slip explosion.jpg
      Its also getting a later model OEM style rear disk brake set up, QA1 coil overs and ThorBros watts link.
      Name:  Scorpion Rear Brakes.jpg
      Name:  ThorBros Flat Plate Watts Link2.jpg
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Nov 2007
      Dayton, Ohio
      The engine is a 70 351C 4V with closed chambers.
      Before I started disassembly.
      I've been buying parts here & there. I have all new ARP hardware, thermostat & housing, Quick Fuel SS-750-AN carb, Hamburger 1" carb spacer, MSD ignition system, Romac double row timing set, Aluminum external oil filter adapter, Hamburger remote filter mount, Mallory electric fuel pump & regulator, Aeromotive primary & secondary fuel filters, Aluminum fuel pump block-off plate, Milodon water pump, Moroso oil breather tank & coolant overflow tank, G+ oil cooler, gauge sending units and Felpro gasket set. I'll be reusing my Offenhauser Port-O-Sonic intake. I'm contemplating dry sumping the oil system or at least using an external pump.
      Intake cleaned up and painted with Eastwood's ceramic engine paint. I really like how it turned out.
      I'm wanting to pull the heads soon and have them rebuilt so I'm currently thinking through the cam and associated valve train I want to use. The top of the short list is Howards P/N 230245-12,
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Oct 2014
      Looking good. That's a ton of fab work!
      1988 Mazda RX7 - Forged LS/T56, 76mm turbo, ProEFI, Ford 8.8 - Sold
      1965 Mustang Coupe - TT Coyote, TR6060, Haltech, big brakes, updated suspension.
      2007 Aston Martin V8 Vantage - Full bolt-ons
      2016 BMW 428iX GranSport - Stock...ish.
      Nov 2007
      Dayton, Ohio
      Thanks digital, I like fab work.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Nov 2007
      Dayton, Ohio
      Making a mount for my coil to attach to the front of the left head.
      Modified my throttle cable bracket for new aftermarket cable.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Feb 2019
      Easley, SC
      Love the pics & progress! Nice work.
      Sep 2013
      sw Kansas
      Is the goal a track or street car?
      Nov 2007
      Dayton, Ohio
      Street, I don't think it would pass any sanctioning body rules with some of my modifications. No big deal though.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      The Netherlands
      Country Flag: Netherlands
      I would not use the Powertrax but get a limited slip.... I had one... gave me traction on both wheels but was a pain in the corners.... just a bit of throttle and it locks causing wheelspin in a corner....specially in the wet it is just dangerous. It is just nice for drag racing.
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Nov 2007
      Dayton, Ohio
      Thanks Martin. Since I already have it, guess I'll see how it goes. I can always swap it out later.
      Got my Scott Drake billet grille from CJPP. First one they sent was bent & distorted, got a replacement a week later.
      Received my LED taillights this week.
      Sandblasted the bottom flanges and found a bunch of pinholes in one.
      Started to weld them closed and shortly after decided it was a lost cause. Also decided to modify the housings by hacking off the back and moving the socket to the left side. Don't need that space anyhow with the LEDs in the lens. Plus gain back some trunk space.
      I need to do a little more cleanup, POR15, then paint. I'll do the other one after I finish cleaning this one. I have new gaskets and hardware also.
      I started working on the door caps for standard door panels. Removed the interior window weatherstrip, straightened the flange afterwards. Ordered new weatherstrip and lock knob grommets. Have to finish cleaning then paint them. I hadn't taken any pics of them.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Nov 2015
      South Jersey
      Quote Originally Posted by 69stang View Post
      Lower dash mod
      Nice build. I'm interested to see what your plan is for the lower dash center section. I have a 69 Cougar which has the same factory lower dash as the Mustang. I moved the AC vents down to the factory radio slot to allow for a Pioneer Carplay head unit to be installed in where the vents used to be. I installed the Vintage Air controller in the factory HVAC control area but it is very hard to see the controls there. So i'm curious what your idea is.
      Good Luck
      69 Cougar
      Schwartz Chassis
      5.0 Coyote
      T-56 Magnum 6 Speed
      Baer Brakes
      Chesapeake, VA
      Great work, I LOVE garage-built cars.
      Cars are meant to be driven.
      John B
      Nov 2007
      Dayton, Ohio
      Quote Originally Posted by lxg44 View Post
      Good Luck
      Moving the vents sounds like a good solution.
      Plan is switches, USB ports and different heater controls. Haven't nailed down the heater controls yet. I have a vision for a remote audio system which has yet to be defined.
      Thanks Jaybee
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Aug 2014
      I am AMAZED no one lost their mind over the square roll bar! lol
      Nov 2007
      Dayton, Ohio
      It's more like rear bulkhead framing. With no rear seat, the area behind is partially open to the rear suspension. How far it intrudes vertically on the space behind the seats depends on the yet-to-be-determined upper link mounting of my 3-link and space needed for mufflers forward of the axle.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Nov 2007
      Dayton, Ohio
      Finished up the taillight housings a few weeks ago.
      Blacked out the trim then assembled
      Stripped, cleaned & primed the interior upper door trim
      Threw some primer on my air dam to check the contour and smoothness. Still have some sanding and skim coating to bring it where I want it.
      Roger
      2011 Mustang - DD
      Freedom Of Speed!
      Feb 2011
      I've always liked the styling of the 69/70 coupes, especially since the FB's are so overpriced. Aren't you concerned about the extra weight of all the square tube?
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
