      Bleed Baer master
      Hi guys, I got a new Baer remaster with the matching proportioning valve and I’m adding a line lock. They’re all new, So are all the lines. I have a Mity Vac to bleed them and was told put all together and use the Mity vac and I wouldn’t need to bench bleed the master because the vac would take care of doing it. Has anyone tried it like this, and did it work?
      Jun 2010
      Deployed
      Is this a question? I have only had good luck bleeding a brake system by the old fashion way using speed bleeders.
      1970 Camaro/DSE build
      Yes it’s a question, I owe you a question mark.... thanks
      Oct 2018
      Phoenix, AZ
      I didn't bench bleed mine and used a Mity Vac to pull fluid through all the lines initially. That still didn't get it perfect, but a handful of old-fashioned bleeds at each corner has everything working flawlessly.
      Mine is a full custom braking system so it was all 100% empty when I started.
      Feb 2013
      I bench bled mine and used one of the Motiv pressure bleeders to get the fluid throughout the whole system (mine was all new as well). Even after that, I still had to go around the car several times and crack the bleeders to get all of the little bubbles out.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Thanks guys
