    Results 1 to 12 of 12
      Oct 2011
      LSA Coolant in Oil Pan
      Hey guys I bought a pullout LSA from a 2015 wrecked ZL1, I pulled the oem oil pan to put on the Holley one and to my surprise there was some milkshake. I was told the engine has only couple thousand miles so I doubt there is a cracked head/block from overheating etc. plus the engine is completely stock no power adders. The only damage I have found is the oem exhaust manifold on the drivers side was slightly warped at the mating surface. Heads are not warped because my new manifolds have a tight fit. Also the bolts for the manifold were warped as well. I see no other damage. The engine turns freely. Most likely the car rolled several times. Would that cause coolant to spill into the oil pan?
