      Jan 2020
      Mann Hummel Pro Vent Plumbing
      I have a 416 LS3 in my Camaro. Dart block and heads, Holley throttle body injection - 600hp. Currently the engine vents into a firewall mounted catch can (see catch can beside a/c firewall lines), with vent hoses plumbed off the back of the thick spacers which sit between the engine block and coil / valve covers on both banks, and thus both sides of the engine feed into the vented catch can - venting to the atmosphere.
      I'd like to go to a Mann Hummel closed vent system, draining back into the sump and I am seeking plumbing advice.
      Is the plumbing as simple as taking the existing hoses from each bank and plumbing them into the Mann Hummel Pro Vent 200 can; plus routing the Mann Hummel drain vent into the LS3 sump?
      that's some nice plumbing! Love the vent on the upper radiator hose.
      ​John Parsons
      Mountain Springs, Texas
      No it is not if I understanding you correctly. You need an inlet and an outlet, not two inlets. I would think you also need a source of clean air.
      Instructions are here.
      https://oe-products.mann-hummel.com/...ProVent_en.pdf
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2020
      Thanks for the advice and the link Don
      Newbury Park, CA
      ............and to add on to what Don says, a PCV valve.
      Thanks Carl. I’m so used to using the stock valve covers this never occurred to me.
      Don
      Jan 2020
      Thanks Carl
