    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 71
    1. #21
      Jul 2007
      nw phx
      hey mate, what part of oz are you from?
      ...life is too short, live for today, tomorrow isn't guaranteed
    2. #22
      Dec 2018
      Quote Originally Posted by Ausssie Nick View Post
      That's what I hope this colour does. It should look nice on the curved panels
      Definitely will
    3. #23
      Aug 2019
      Quote Originally Posted by BK2LIFE View Post
      I'm from Toowoomba in QLD
    4. #24
      Aug 2019
      Finally got the underbody primed in epoxy over the weekend. Plan now is to test fit the ridetech 4 link before getting the underbody painted in colorName:  underbody 2.jpg
Size:  313.9 KBName:  underbody.jpg
    5. #25
      Looking Good!
    6. #26
      Sep 2017
      Awesome progress keep up the pushing.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    7. #27
      Aug 2019
      Floor is finally painted!
      HI All,
      Had a productive weekend. the floor is finally painted. It came up great. I also test fitted the ridetech 4 link on the weekend. The cradle does not fit as there is manufacturing differences in this era of cars according to ridetech. After a bit work I need to have a few spacers cut to put between the cradle and chassis rails. We have a computer waterjet cutter at work so I will get some spacers cut that are neat and match the profile of the cradle. I will post some pics of the instillation of the 4 link. The Plan this coming weekend is to repaint the firewall as there are a few more holes that I would like to weld up. We will also repaint the interior black. All going well I should be able to put the subframe back under the car over Easter. Name:  Painted floor 2.jpg
Size:  535.3 KBName:  Painted floor 3.jpg
Size:  509.3 KBName:  Painted floor 8.jpg
Size:  450.7 KBName:  Painted floor 9.jpg
Size:  400.5 KBName:  Painted floor 10.jpg
    8. #28
      Aug 2019
      4 link is now installed. This weekends task will be to repaint the firewall
      Name:  4 link installed.jpg
    9. #29
      Aug 2019
      Firewall and dash complete
      Hi all. Had a productive weekend. The firewall is now repainted. This was necessary as I welded up the holes where the heater lines went through the firewall. I am going to install a vintage air system and wanted the firewall to look as clean as possible. We also repainted the interior of the car. I have decided to go with a black interior. I am now ready to install the subframe. The new Tremec TKX should arrive this week. I should be able to make some good progress over Easter.
      Name:  Dash in black #2.jpg
Size:  290.1 KBName:  Dash in black.jpg
Size:  340.6 KBName:  Finewall completed #2.jpg
Size:  395.1 KBName:  firewall completed.jpg
    10. #30
      Aug 2019
      My new TKX arrived yesterday. Looking forward to putting the sub frame under the car, and mounting the engine, gearbox and diff over the Easter long weekend
    11. #31
      Aug 2019
      Made some progress over the Easter long weekend. mock-up Engine and transmission are now installed. I have installed the radiator support panel and radiator for mockup purpose. This will allow me to mock up turbo and intercooler piping. Once I am happy with the turbo piping I will remove the radiator support and get it painted.
      Next step is to mount the 12 bolt diff under the car so I can weld the ridetech 4 link brackets onto the housing. I will also start looking at what accessory drive will work on the LS. I am open to suggestions that look nice but don't break the bank. Utilizing some stock parts with upgraded pulleys may be an option. I will need to run A/C, Alternator, Power steering and water pump.
      Name:  Engine and gearbox.jpg
Size:  445.1 KBName:  engine install.jpg
Size:  386.1 KBName:  Engine installed.jpg
Size:  407.9 KBName:  Radiator mockup.jpg
    12. #32
      Jul 2019
      Ohio
      Looking great!
    13. #33
      Excellent progress. How did the TKX fit in the transmission tunnel?
      Instagram @projectgattago
      Dr. EFI
    14. #34
      Sep 2008
      You are moving quickly. What paint did you use on the interior floor sheet metal? Thanks
    15. #35
      Aug 2019
      Hi Andrew. The TKX fits with plenty of clearance. I used trans department 1 1/4 inch setback engine mounts. There is still plenty of rom around the transmission
    16. #36
      Aug 2019
      Quote Originally Posted by CARLMB View Post
      I primed it in Epoxy primer first and then used Tex coat chip guard from transtar. It went on really nice. I also used the tex coat in the rear wheel tubs before applying color
      Name:  floor paint.PNG
    17. #37
      Mar 2020
      Winnipeg, Canada
      Cool Build...
      Cool build! Look forward to following.
      You're a little ahead of me... Nice to see what I'm store for.
    18. #38
      Jul 2019
      Ohio
      Looks like getting to those 2 last rear horizontal bolts for the 4 link to frame rail was a challenge? I'm working on installing my 4 link now, doing some messaging on the trunk pan to get it to fit up tight and was thinking drilling those last to bolts look pretty darn near impossible to drill.
    19. #39
      Aug 2019
      Quote Originally Posted by srode View Post
      Yes you are right. I still need to figure out how to get them in. Messaging the floor is not an option for me as it is all painted now. If you figure out a way let me know as it is still on my to do list.
    20. #40
      Aug 2019
      Quote Originally Posted by Kuhlhaus View Post
      Hi Ken,
      Just had a look at your build. You're doing a great job! Not to much longer and all the dirty work will be done. It sure is nice when the car is painted and all of the work involves reassembly. The stage your at I found most challenging to remain motivated.
      Nick.
    Tags for this Thread
