      Dec 2011
      new york
      Harmonic balancer ac pulley
      I have an ati balancer I am installing on my L76. It has the second pulley for the ac, but with my holley bracket I do not use the second pulley. Can I and is it worth it to remove the second pulley It just bolts on? I would have to hone out the holes on the balancer though to run bolts in the pulley holes. The pulley weighs about a pound.
      Jun 2010
      Deployed
      Quote Originally Posted by 1985olds View Post
      Personally I would just run it as is, it just won’t be used. I did this in my LS1 when I ran a AC relocation bracket to the upper passenger side. If I recall correctly there are bolts that are longer that go through the front pulley through the hub to the rear pulley. You should be able to not even use it without mods, you’ll just need shorter bolts. But ask ATI to be sure.
      1970 Camaro/DSE build
      Dec 2011
      new york
      You are correct on the longer bolts. The holes need to be opened up a little for a larger bolt. I spoke to ati twice and one tech rep said no, one said yes. I'm wondering if the juice is worth the squeeze to save 1 lbs of rotating weight
      Jun 2010
      Deployed
      I honestly don’t recall that AC pulley even weighing that much being aluminum. I ran it with no issues, to avoid the headache either run it or look for a non AC version.
      Dec 2011
      new york
      I had it on the scale, it is 1 lbs. I think you are right, I'll save the $10 on new bolts and run as is. Thank you.
