    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 52 of 52
    1. #41
      Here is a Matlab script I whipped up to calculate spring rates / suspension frequencies.
      I adopted the forumlas from various websites (and my undergrad physics textbook) and I'm not 100% sure I have things right (I'm waiting for my copy of RCVD to show up). The vehicle constants are rough approximates for my 69 Firebird.
      vehicle_weight = 3400; %total vehicle weight
      f_weight_dist = 0.54; %front weight percentage
      f_wheel_unsprng = 100; %front wheel unsprung weight (per wheel)
      r_wheel_unsprng = 200; %rear wheel unsprung weight (per wheel)
      f_mr = 8./16; %approx. front motion ratio from LCA
      r_mr = 0.9; %approx. rear motion ratio (live axle)
      f_sprate = 850; % given front spring rate (lb/in)
      r_sprate = 250; % given rear spring rate (lb/in)
      f_damp_ratio = 0.35;
      r_damp_ratio = 0.35;
      f_freq = 1.7; %Hz
      r_freq = f_freq + 0.15.*f_freq; %Hz, rear freq is 15% greater than front freq
      wheelbase = 100; %approx. (inches)
      avgspeed = 80; % mph
      % convert to SI units
      fmass = ((vehicle_weight.*f_weight_dist)./2-f_wheel_unsprng).*0.45359237;
      rmass = ((vehicle_weight.*(1 - f_weight_dist))./2-r_wheel_unsprng).*0.45359237;
      f_sprate = f_sprate.*175.126835;
      r_sprate = r_sprate.*175.126835;
      % calculate wheel rates
      f_wheel_rate = f_sprate.*(f_mr.^2);
      r_wheel_rate = r_sprate.*(r_mr.^2);
      % calculate undamped spring rates given frequencies
      Ksf = 4.*(pi^2).*fmass.*(f_freq^2)./(f_mr^2)./175.126835
      Ksr = 4.*(pi^2).*rmass.*(r_freq^2)./(r_mr^2)./175.126835
      % calculate undamped frequencies given spring rates
      f_freq_undamp = (1./(2.*pi)).*sqrt(f_wheel_rate./fmass)
      r_freq_undamp = (1./(2.*pi)).*sqrt(r_wheel_rate./rmass)
      %calculate damped frequencies given spring rates
      f_freq_damp = f_freq_undamp.*sqrt(1-f_damp_ratio.^2)
      r_freq_damp = r_freq_undamp.*sqrt(1-f_damp_ratio.^2)
      % calculate damped time constants
      f_tau = (2.*pi).*f_freq_undamp.*f_damp_ratio;
      r_tau = (2.*pi).*r_freq_undamp.*r_damp_ratio;
      % whip up time independent variables
      tf = linspace(0,f_tau,1000);
      f_to_r_timlag=wheelbase./(avgspeed*63360/3600);%time lag from bump front to rear
      tr = tf-f_to_r_timlag;tr = tr.*(tr >= 0);%offset rear time, get rid of neg times
      % plot damped trajectories
      figure(1); clf;
      plot(tf,exp(-f_tau.*tf).*sin(2.*pi.*f_freq_damp.*tf));hold on;
      plot(tf,exp(-r_tau.*tr).*sin(2.*pi.*r_freq_damp.*tr),'r');hold off;
      title('damped suspension trajectories');
      xlabel('time (s)'); ylabel('amplitude (arbitrary units)');
      Results:
      Ksf = 967 lb/in, front spring rate given 1.7Hz (undamped)
      Ksr = 281 lb/in, rear spring rate given 2.0Hz (undamped)
      f_freq_undamp = 1.6 Hz, front freq. given 850 lb/in spring rate (undamped)
      r_freq_undamp = 1.8 Hz, rear freq. given 250 lb/in spring rate (undamped)
      f_freq_damp = 1.4931 Hz, front freq. given 850 lb/in spring rate (damped 35% of critical)
      r_freq_damp = 1.7280 Hz, rear freq. given 250 lb/in spring rate (damped 35% of critical)
      Attached is a plot of the front and rear trajectories:
    2. #42
      Nov 2002
      state of confusion
      Looks pretty good, although 200 lbs per rear corner sounds a bit high unless you have a real beast of an axle. Are leaf springs really that heavy (remembering that perhaps a third to half of their weight is sprung)?
      I ran a sanity check for one of my spreadsheets and got . . .
      Ksf = 965 lb/in, front spring rate given 1.7Hz (undamped)
      Ksr = 293 lb/in, rear spring rate given 2.0Hz (undamped)
      Note that Ksr = 280 lb/in if I use 1.15*1.7 = 1.955 Hz instead of 2.0 Hz.
      f_freq_undamp = 1.60 Hz, front freq. given 850 lb/in spring rate (undamped)
      r_freq_undamp = 1.85 Hz, rear freq. given 250 lb/in spring rate (undamped)
      f_freq_damp = 1.49 Hz, front freq. given 850 lb/in spring rate (damped 35% of critical)
      r_freq_damp = 1.73 Hz, rear freq. given 250 lb/in spring rate (damped 35% of critical)
      (Sorry for the crappy thumbnail resolution - it's easier to see as a full screen display and then expanded with the sizing button in the lower right hand corner.)
      Norm
      Gone but not forgotten dep't:
    3. #43
      Cool, thanks Norm. After I posted, I thought that the rear unsprung weight should have been about half of what I entered. D. Pozzi has 110 lbs (per rear wheel, 220 total) unsprung weight listed on his web site.
    4. #44
      Central CA USA
      I forgot to include the weight of the wheels and tires in that calculation!
      Here's some info:
      REAR SUSPENSION
      rear axle 12 bolt with drm brks, posi -complete 185
      leaf spring - multi stock 32
      Hotchkis type leaf closer to 40 - 45.
      shock 3
      Wheel and tire is around 50 lbs
      sway bar is probably around 10 lbs
      I think you'd take half the weight of the spring, bar, and shock.
      somewhere around 287 lbs total depending on your exact wheel/tire weight.
    5. #45
      England
      would you not have to take the weight of the driver , and tire pressures ?
    6. #46
      Nov 2002
      state of confusion
      (1) Best results would consider the driver's weight and his own CG location. And the weight and CG of any other variable loading.
      (2) Tire pressures will make a generally small difference, but this effect isn't very usable unless you have some idea of the correlation between inflation pressure and tire vertical/radial spring rate.
      Norm
    7. #47
      Auburn, WA
      Just for a reference, Racecar Engineering quotes:
      1 Hz for Caddy rides
      1.3Hz for sports cars
      1.8Hz high performance road cars
      2+Hz for racecars w/o aero aids
      It also mentions that ground effect racecars could have attained up to 10Hz! Wow!
      Anyway, my personal experience hasn't followed the above guidelines. I've done vehicles with a frequency slightly above 2.0, and it had a very pleasant ride with excellent handling (.95G).
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
    8. #48
      TN
      I know this is a REALLY old thread... But none of the links work. Does anyone have any new info or spreadsheet links?
      Thanks!
      Benjamin
      Benjamin
      Twin Dusters
    9. #49
      Nov 2002
      state of confusion
      What links?
      All I see are thumbnail pics.
      I probably have one version or other of my sheet on most of the computers I ever use, but nowhere that can be linked to directly.
      Norm
    10. #50
      Rustburg, Virginia
      Quote Originally Posted by Norm Peterson View Post
      What links?
      I guess he was speaking of David's link in the first few posts in the thread....
      Quote Originally Posted by David's link
      Sorry, the GeoCities web site you were trying to reach is no longer available.
    11. #51
      TN
      Quote Originally Posted by John Wright View Post
      Yes that was it. So nobody knows of another one that I can get too? Or how I could possibly get my Grubby little hands on one of those spreadsheets? I suck at excell.
      Benjamin
      Twin Dusters
    12. #52
      Nov 2002
      state of confusion
      If you PM me with an e-mail address, I can send out the latest version that's on this computer.
      Forum e-mails don't generally permit attachments.
      Norm
