    Results 21 to 40 of 57
    1. #21
      Oct 2019
      Some progress on the front cross member. I don't know what happened but my welding was exceptional last night.
Size:  223.8 KBName:  002.jpg
Size:  263.6 KBName:  003.jpg
Size:  163.4 KBName:  004.jpg
Size:  219.7 KBName:  005.jpg
    2. #22
      Jul 2008
      ohio
      sweet build
    3. #23
      San Antonio, Tx
      Quote Originally Posted by croooksie View Post
      We all make a mistake now and again
      Instagram: CamaroAJ
    4. #24
      Oct 2019
      Been busy, got the front end just about knocked out.
Size:  252.9 KBName:  002.jpg
Size:  219.5 KBName:  004.jpg
Size:  225.3 KBName:  005.jpg
Size:  293.7 KBName:  003.jpg
Size:  239.4 KBName:  006.jpg
    5. #25
      Wow impressive! Nice work.
    6. #26
      Jun 2015
      Country Flag: New Zealand
      what are you rear rockers pivoting on? cool build btw
    7. #27
      Oct 2019
      Quote Originally Posted by Gmc427 View Post
      Just a bolt, I messed up on the design, but I'm going to remedy it by sleeving the middle of the support tabs as well as the out side edges of the rockers. And to ensure they aren't pinched ill use locking nuts and only snug them up. Or at least that is the plan for now.
    8. #28
      Oct 2019
      If anyone here has experience putting a brake system together i would appreciate some input! I ran some calculations to determine master cylinder sizing compared to my over sized calipers I plan on running and came up with the following.
      What i am unsure on currently is what is the typical clamping force seen on a track car and what is the travel distance a brake caliper piston would typically see under driving conditions. As of right now I see around 3500lbs of clamp per caliper at 0.03" travel at 70lbs input force at the pedal.
    9. #29
      Oct 2018
      San Jose, CA
      There must be an error in your math.
      No way .03” travel will get anything done.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
    10. #30
      Oct 2019
      Quote Originally Posted by c4racer2 View Post
      That's an input value (my estimate) of the stroke one piston will move under braking. How much do you figure they move? When a system is bled and sitting in a resting state the brake pads basically sit right on the rotors surface. My logic was that there is very little movement required to begin stopping the vehicle?
    11. #31
      Oct 2018
      San Jose, CA
      That’s not the case. The piston on the MC travels more than 1”
      2018 Colorado 4x4
    12. #32
      Oct 2019
      https://www.wilwood.com/mastercylind...no=261-13626-P
      This is where I got the MC stroke from. Wilwood's spec stroke is 1.1".
    13. #33
      Oct 2018
      San Jose, CA
      Right and the brakes start to engage maybe 1/3 of the way into that 1.1” stroke.
      Something around .3”
      Not .03”
      2018 Colorado 4x4
    14. #34
      Oct 2019
      Not .03”
      I get where your confused. I'm talking about the piston stroke on the CALIPERS. I'm estimating the caliper pistons only travel 0.03", not the MC. I know what the MC travels from the data from Wilwood.
      That's what i want to confirm, how much the caliper pistons need to travel to stop the car. I'm going to just run with that figure for now and see how it all works when it gets here. I'm guessing its pretty close.
    15. #35
      Oct 2019
      Progress update, waiting on a ton of parts currently
      The red car in the last picture is one of those Factory Five kit cars. My little brother just picked it up on the weekend. They are quite the machine.
Size:  292.5 KBName:  002.jpg
Size:  331.9 KBName:  003.jpg
    16. #36
      Oct 2019
      Had a bit of time on the weekend, so got the car back on the ground.
Size:  269.1 KBName:  002.jpg
    17. #37
      Oct 2019
      Update. Did lots. Pretty sure my over kill exhaust will drag on the ground so not sure what to do there but hey, might be running soon here.
Size:  220.4 KBName:  002.jpg
Size:  210.0 KBName:  003.jpg
Size:  102.5 KBName:  004.jpg
Size:  166.7 KBName:  005.jpg
Size:  308.7 KBName:  007.jpg
Size:  297.8 KBName:  007.jpg
    18. #38
      Oct 2016
      What a nice build ! Love it
    19. #39
      Oct 2019
      Quote Originally Posted by berdunord View Post
      Thanks!
      Missed another photo, really like this shot. Kind of wish the supercharger wasn't in the way now blocking off the drivers side.
    20. #40
      Oct 2013
      H-Town, TX
      Amazing creativity. Love the build
