    Results 1 to 20 of 26
      Aug 2016
      Tampa FL
      what aftermarket subframe will take my current 1st gen components ?
      I need to replace my original 67 Camaro subframe, but would like to keep my already upgraded components. Is there an aftermarket frame that I can bolt my current upgraded sway bar, tubular a arms, coil-overs, and Brakes onto ?
      Pensacola, FL
      Why not get a new AMD stock replacement subframe?
      Aug 2016
      Tampa FL
      I need some more room for my front tire / wheel combo to not rub at full turn. And I want to stop dragging the center support that leads the tires on my lowered suspension. And to avoid having to weld all the joints of stock frame again
      Check with Speedtech.
      Aug 2016
      Tampa FL
      I checked with speedtech , their subframe uses only their proprietary suspension and steering components
      Pensacola, FL
      What brand components are you running, and what size tire would you like to run up front? 265 is doable on a 67/68 without a lot of work, and Ive seen a few w 275s. What exactly is dragging? Are you rubbing the frame or sway bar? And how low is it?
      Aug 2016
      Tampa FL
      QA1 coilovers on Global West a-arms, dropped 2.5 inches, on stock drum spindles with 13" C4 rotors, steering with late IROC steering box and short 67 steering arms. My 235 x 40 x 18 tires n 8"wheels with 4.5 offset rub frame at full turn
      Huntington Beach, CA
      There aren't any aftermarket frames that give the additional tire clearance you are looking for that will allow you to use those parts. Excepting maybe the brakes. I was in a similar place as you and decided to sell my original frame with all of the upgraded aftermarket parts and bought a complete aftermarket frame setup.
      Pensacola, FL
      You should be able to run that tire size without issue. Does the tire rub on the front side, back side, or both? The backspacing sounds about right, but I have not run that brake/spindle combo before. Try a 1/4" wheel spacer and see what effect that has.
      Mountain Springs, Texas
      Quote Originally Posted by Z06vet View Post
      X2. Sounds like you need some steering stops.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Aug 2016
      Tampa FL
      Id like to keep turn radius and ride height. still have subframe drag before tires. looking for constructive help please
      Quote Originally Posted by Dark Pursuit View Post
      My suggestion was constructive, you just didn’t like it.
      Those tires should work without issue. I’ve run a 255 on the stock subframe without rubbing.
      If you are dragging the subframe crossmember then your car must be very low.
      Good luck with your quest, or is it a pursuit....
      Don
      Pensacola, FL
      I have never dragged a subframe on 2.5" drop. Show us some pics
      Michigan
      You could "notch" the stock subframe for additional tire clearance at full lock. Sounds like CPP has a kit in the works.
      From this article: https://www.hotrod.com/articles/1906...ance-products/
      "CPP accomplished this feat with a side-notch kit on the front clip. This is a new product designed by CPP engineer Danny Nix that allows a 315 tire to fit up front. While not yet available, CPP is working to bring the kit to market as soon as possible. “We’ll put it in production the first chance we get,” said Ries. “It’ll be easy to do for guys that like fabrication. It’s a very straightforward install.”
      Regarding how to get additional front crossmember ground clearance, I don't have any fast answers, but as others have said, your car must be super low to be having that issue.
      - Ryan
      You lost your steering stops when you replaced the factory lower control arms. You are not sacrificing turn radius when you add stops that stop it just short of hitting the subframe. There should be no need to notch the subframe for a 235 tire.
      Don
      Aug 2016
      Tampa FL
      Thanks Ryan, I was considering notching the frame. But I did not know about the kit. This is my 5th 1st gen, and my most invested. Frame cross member is not the issue, it is the 10" piece in the center that has dragged on all of my cars at most speed bumps, as it extends out before the front tires. Maybe Ill just remove and replace with 1/4 in plate if no aftermarket frame can accept my upgrades. My frame is bent, so will need replacement anyways.
      Michigan
      I also have 235/40R18's on 18x8 rims with 4.5" backspacing and a 2.5" drop on stock A-arms, and there's a tiny bit of rubbing at full lock. It's not enough to matter; it hardly even scuffs the paint on the subframe.
      If it were my car, I'd take Don's suggestion and add some steering stops. Way cheaper and easier than modifying/getting another subframe, and you'll probably end up with 99% of the max steering lock of a stock car.
      If I remember correctly I have 3.5" of crossmember clearance, which has never been a problem for me.
      - Ryan
      Michigan
      Got it, your question makes more sense with this additional context.
      - Ryan
      Aug 2016
      Tampa FL
      subframe
      Yeh, same amount for me, which I dealt with before the car was totaled, Just want to eliminate on build number 2. The brace drag has always me, and it seems there are 10 speed bumps going into any show.
      Michigan
      Sorry about your car :(
      Hopefully your insurance company took care of you.
      - Ryan
