    Results 1 to 15 of 15
      Jun 2012
      LED Headlights for 67-68 Camaro
      I was wondering if anyone knows of a high quality LED replacement headlight for a 67-68 Camaro. I'm not concerned with cost. I just want the best quality available
      May 2014
      Stanislaus County Ca.
      I don't like the ones that look like they come off a multi winged Asian built car
      But here are a couple links to look at.
      http://www.truck-lite.com/webapp/wcs...atalogId=10002
      https://www.jwspeaker.com/products/c...es/headlights/
      I have the truck light 27270C, they'll due for now until I find something I like a little more.
      Feb 2011
      dallas, tx
      Truck lites with upgraded headlight wiring harness are amazing. Equal to my 2015 infiniti q50
      https://www.americanautowire.com/sho...ncer-relay-kit
      Feb 2018
      Southern IN
      Trucklight 27270C...you won't be sorry. They dropped right in my 68 Camaro. No bucket mods, no ballasts, no problem.
      Shane
      #theanchorholds
      68 Camaro build thread:
      http://lateral-g.net/forums/showthread.php?t=56387
      Nov 2014
      Lake Worth, FL
      Check out Octane Lighting.. I have them in my 68 & 69 camaro's, plug and play, no cutting of the light buckets at all, no ballast and very bright
      Dec 2010
      Fredericksburg, VA.
      The Trucklite 27270C is a very popular direct fit requiring no modifications along with a relay headlight harness upgrade as described in the following link.
      http://madelectrical.com/electricalt...adlights.shtml
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Arizona
      The beauty of LED headlights is you Don't need the additional wiring and relays that are needed for the huge amp load for HID and Halogen lights. LED light need a third the current that the others need. LED headlights use less current than the old original sealed beams that came in the old cars.
      Jacksonville, FL
      I have the trucklites in my 68 also. Great lights!
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jul 2013
      Gilbert, AZ
      I'm a fan of the Truck-Lites as well, personally. I think they are the best looking LED 7" headlamp on the market, too many others look bug-eyed or too busy.
      Apr 2019
      Quote Originally Posted by CampbellshotrodsAZ View Post
      Trucklite is def one of the better ones
      May 2014
      Looks like trucklite is the common one. I'll eventually find an LED that looks more OEM style and swap them out.
      Jonesboro, Arkansas
      I have a aftermarket LED in my '68 Camaro. I bought the housing (with the glass front) and put a LED light in it. Looks just like the original and the cost is around $85 for the pair. Bright as Any other and have not had a problem in 2 years.
      Carl Wilson
      Oct 2015
      We installed a set of these in a customers 68. They fit great with no modifications to the buckets. Even work good with the hide aways.
      https://www.summitracing.com/parts/ann-881035/overview/
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by oleyeller View Post
      While is it true HID and Halogen bulbs draw a lot of amperage, the headlight relay mod is actually about addressing the issue of voltage drop. The fact is that the factory headlight wiring of the typical 60s GM vehicle was lacking in that there was a significant voltage drop by the time the power was routed through the headlight switch and out to the headlights. A voltage drop to the tune of around 11v from 14.5v is normal in these cars no matter what headlight you run. So even the LED headlights benefit from the voltage increase of headlight relay upgrade. I would argue that the headlight relay mod should be done regardless of what headlights are installed.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Arizona
      Worth it or not?
      I respectfully disagree with the "need" for additional wiring and relays for Truck Lites 27270C, which use at max output 2.95 amps per bulb. Using a voltage drop calculator, the voltage drop is negligible. I prefer the KISS method, less stuff to fail, hide or buy. Just my opinion and I know everyone has one.....
