      Oct 2015
      Caliper to wheel clearance
      I'm running c6 z06 brakes with kore 3 hubs and brackets. The spokes to my wheels wouldn't clear the calipers. Even with a 3/16 spacer, I have 1.5mm of clearance at the tightest spot. What is the minimum clearance needed for these brakes? The wheels are cheap ridler 650s that I'm trying to make work until I can get something custom made.
      Apr 2012
      Woodstock, IL
      My comfort level is 1/8" or more.
      You could probably get away with 1.5mm or 1/16".
      Do you have room on the studs to go with a 1/4" spacer though?
      -Dale
      SchwartzPerformance
      Oct 2015
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      Not without going to longer studs, which I'll probably do to be on the safe side.
