Results 1 to 13 of 13
12-11-2005 #1
Questions for the people in the know....
Ok guys,
I have been following tech info for about a year now. I'm going to list what I have done to the car. Please help me in determining what I did right and what might need to be corrected. This car is going to be driven on the street only, no track use. Your comments good or bad are appreciated. Remember I'm a rookie and have been using the knowledge of others on this board. Some of the tech threads are over my head. Cost has not been a concern on this project.
69 GTO Judge
Suspension
Factory frame
Global West front lower and upper control arms. D-bushings
3" lowering springs by OPG
QA1-Shocks
1 1/8 front sway bar
Factory B-Spindles from Baer
The top ball joints on the upper fronts contol arms were replaced by GW with smaller units. Less bulky (flatter). They said they were needed for the lower suspension height I was using. I really don't understand this one.
Global West rear lower and upper control arms. D-bushings except top of rear axle bushings are rubber.
QA1-Shocks
No rear sway bar
Note: 68-69 Factory GTO's sit higher in the front. I wanted to go coil overs, however, the adjustment was not enough to alter the ride height to where I now have it, which is 1" lower ride height in the front compared to the rear. That includes putting wheels of 18's in front and 20's in the rear.
Baer also supplied me with some big ass tie rod ends with their name on them.
AGR quick ratio steering box and pump.
Is my ride going to be harder then the factory ride?
I would think most of my wheel hop in the rear should go away?
Will I encounter more bump steer then a factory set up?
It's got to handle a whole lot better. Correct?
Feel free to ask me more questions if needed.
R.P.
