Thread: Accusump and check valve
04-09-2019 #1
- Jun 2006
- 167
Anyone out there run an Accusump?
Thinking I will go from adapter to remote filter to thermostat w/ oil cooler and T in after the t-stat w/ a check valve on one side and the Accusump and the return back to the engine on the other side. Pretty sure this is how it is supposed to be. Curious if anyone is running this set up.
04-10-2019 #2
- Jun 2006
- 167
The more I think about it, since the Accusump needs the check valve anyway, it doesn't matter where as long as it is downstream of the filter.
That said I may just put it on the outlet of the filter housing. That way when you swap the filter the oil won't drain down out of the cooler. Not sure if it would matter much since the thermostat would be closed anyway.
04-10-2019 #3
