    Results 1 to 7 of 7
      Rochester, MN
      TH400 crossmember
      Sorry if this is in the wrong section. But im looking for help with a transmission Crossmember. I am running a TH400 with a gearvendors O/D in a 72 SS Chevelle. Its a BBC with a 12 bolt. I have the stock crossmember but obviously with the Gearvendors its not fitting correctly. Any one have suggestions. Modify the one if have?. Have a tube crossmember built? If so, any suggestions on who can do that?
      Thanks for any suggestions
      Chris
      Feb 2009
      So-Cal
      what kind of car is it? I used a stock th400 crossmember with the same setup and it worked fine...
      James Faria
      07 GT500 740rwhp
      Rochester, MN
      Hello, it is a 72 SS Chevelle that I put a BB into. I am using the stock cross memeber which came from the orig th400. ( My car is an orig 350/th400 car). I purchased a street strip Hughes Tranny and added a GV overdrive. and for some reason the Cross member is not lining up.
      thanks for any suggestions.
      Chris
      Feb 2009
      So-Cal
      do you have it the right way meaning have you flipped it around, you can put it both ways the trans tab facing the front or the rear.
      James Faria
      07 GT500 740rwhp
      Miami, Fl.
      I have a turbo 400, GV in the Caprice. I had to cut and fabricate the transmission brace for the GV to fit. It's all worth it. I think I have some pictures, I look for them and upload later.
      Rochester, MN
      Excellent. If you happen to have any pictures that would be very helpful.
      Again thanks for anyhelp. I love to get this running soon:-)
      Quote Originally Posted by 67 caprice View Post
