Results 21 to 31 of 31
Thread: 200-r4 Vs. 700-R4 Which One?
02-08-2006 #21I am having a 2004R built now. It will be using a CZ core, 86-87 Monte Carlo SS, alto red clutches, GN servo, deep pan, billet forward drum, etc. and will withstand low to mid 10 sec blasts in the 1/4 mile. PM me if you want more details.
Originally Posted by 68ls1wannabe
02-14-2006 #22Let me stress the importance of correct CV cable adjusting! I burned up a fresh 700-R4 on a 64 chevelle that I use to own. It's a major PITA! You have to run a special bracket on a Holley carb if you want to set it right. The swing on the carb is the wrong radius for the CV pull. There is a special little bracket that ajust's the ratio. Make sure you get it ajusted correctly too, and not just by feel.
The beyond 3/4 throttle in 3rd gear wasn't that big of an issue because I rarely above 130. With my gear ratio I was passing the traps in the 1/4 in 3rd at 6,600 (on spray).
Hope this helps.~Ryan
02-18-2006 #23The 700-R4 has a greater spread between first, second, and third gears. You will have more pickup off the line with one. It also has a greater spread between first and overdrive. If you have a wide powerband and want power and economy you might be better off using the 700-R4.
Running a high-stall converter is going to hurt mileage when the clutch is unlocked. On the highway a 1200 stall is the same as a 5000 stall if the torque converter clutch is locked.
One of the things that allows a high stall to have good drivability is a higher STR (stall/torque ratio). This number coorelates to the torque multiplication of the converter. Mind you, as the converter slippage reduces so does the multiplication, and higher STRs usually have reduced efficiency, so just like choosing a cam, the bigger number is not always the best.
03-23-2009 #24Here is another article to fuel the debate. Illustrating the 700 being built stronger. I recognize this is comparison of stock units.
http://www.webrodder.com/article.php?AID=426&SID=6
Also, from what I have read if you are running a lower HP/TQ motor the 200 may be have more suitable gearing with the 1 -2 shift. With 450 and up HP/TQ there should not be any issues of "falling down" from 1st - 2nd
Transmission Ratios
200-R4 1st - 2.74 2nd - 1.57 3rd - 1.00 4th- 0.67
700-R4 1st - 3.06 2nd -1.62 3rd- 1.00 4th - 0.70
In the end I think it comes down to the build/parts and builder.70 Nova - 406 sb -488 HP/504 TQ-3:73's
http://s66.photobucket.com/albums/h266/steelratnova/
04-09-2009 #25
- Jan 2005
- Netherlands
- 1,012
Bowtie overdrives Level III tr2004r 170mph drive bij http://www.youtube.com/watch?v=7Dp0PngisVI
04-09-2009 #26
