    Results 1 to 20 of 20
      Mar 2017
      Sydney Australia
      Country Flag: Australia
      Wipple or Magnuson
      Hi Guys,
      I am in the process of putting together a 69 Gto and am doing an LS3 swap with a blower. question any preference between a Whipple or a Magnuson?
      just looking for opinions
      thanks in advance
      Mark
      Apr 2012
      Woodstock, IL
      Are you considering the Whipple 2.9 vs Magnuson 2.3?
      Or another size?
      In my opinion, choosing blowers is like choosing oil. They will have minimal differences.
      However, if you're keeping the LS3 stock and throwing a blower on it, I'd go the Mag 2.3L as you don't really need 2.9L.
      If you're building a higher hp monster, then stepping up to a 2.9L may be the way to go.
      Consider the serpentine drive system options as well. Wegner & Concept One make them for various blowers.
      -Dale
      SchwartzPerformance
      Mar 2017
      Sydney Australia
      Quote Originally Posted by Schwartz Performance View Post
      Or another size?
      -Dale
      Hi Dale
      thanks for you imput
      Nov 2014
      What are your goals? Both options can do over 800rwhp.
      You should also consider the new Magnuson R2650 if your are aiming for higher horsepower goals. That said if you aren’t really looking for more than 650-700rwhp then you might also consider the LSA supercharger for a substantial savings.
      Mar 2017
      Sydney Australia
      Quote Originally Posted by Dave95Z28 View Post
      Hi Dave,
      We are looking for around 800 rwhp and ill take a look at the R2650
      Aug 2016
      Marietta, GA
      I am very happy with my 2.9L whipple on the LS3. Great drivability, low power loss when not in boost, and room to turn it up more at a later date if you want. It is a really clean package. I am running about 12lbs currently.
      Oct 2013
      I’m considering a Whipple upgrade and have been researching the different Superchargers and have decided to go whipple. The reason is the ability to support around 1000 plus horsepower and run up to 12 psi boost using Whipple pulleys. I like knowing that a very expensive upgrade can grow as the engine develops over time.
      Jun 2012
      Golden Valley AZ
      Quote Originally Posted by GS455vert View Post
      This is good to know, as I have thrown the twin turbo idea out the window on my 69 Camaro build and I am also looking at the 2.9 Whipple instead. I'll be running a 6.0L in mine. Looking for around 700 to 800HP
      John Rodko
      69 RS/SS Camaro.
      Heidts Pro G IRS w/ 3:90 gear, Heidts Pro G front
      6.0L LQ4 to be TT
      6 speed or 4L80E, that is the question..hmmm
      Future plans for full TMI interior
      Jul 2007
      nw phx
      i have had way better customer service with magnuson.
      ...life is too short, live for today, tomorrow isn't guaranteed
      Jul 2019
      Ohio
      Quote Originally Posted by Rodknock View Post
      Will a Whipple fit under your hood? I was considering an Eforce system on an LT build for my 69 Camaro due to the low profile, it should fit without cutting up the hood.
      Jun 2012
      Golden Valley AZ
      Quote Originally Posted by srode View Post
      I actually don't know for sure. I have a 4" AMD cowl hood. It might require some trimming of the inside, but I don't know for sure.
      John Rodko
      69 RS/SS Camaro.
      6.0L LQ4 to be TT
      Red Deer, Alberta, Canada
      Ive seen Magnusson heartbeat lids fail on max effort deals. I also dont like how poor magnusons delivery times are. They pump a product online, such as the 2650 and it took what 2 years for the first average joe to see one? The TVS2300 with a cog drive rear belt has proven to be a great, reliable performer. Standard rear belt is fine if its not pullied aggressively.
      The whipples have always been reliable, but are typically harder to package. Taller, Some are rear snout throttle body, blower pulley centered as opposed to side shaft on some Magnuson models.
      I dont think you can go wrong either route.
      Matt
      Instagram: Cst_koon
      Feb 2011
      dallas, tx
      What kid failure did you see with the heartbeat blower? I love mine. Ordered and had it within a week
      Quote Originally Posted by icemanrd19 View Post
      max effort deal, pullied it hard and split the lid, one was a nitrous backfire. Its a weakness of lid type blowers.
      Matt
      Instagram: Cst_koon
      Dec 2018
      Quote Originally Posted by r67nova View Post
      Did you change any of the internals? Thinking of putting the same blower in my car right now and trying to figure out what else I may need to look at. My motor already has the GMPP Hot Cam in it, but thinking I may need to look at heads, cam and obviously injectors and more than likely a fuel pump upgrade.
      Aug 2008
      Dallas, TX
      John, the Whipple 2.9L will fit under the 2" cowl hood just fine. I have a Whipple 4.0L and had to slightly modify a 2" cowl hood. So, the 2.9L is smaller in size and will fit no problem. You can barely tell my hood was modified too. Last pic is really dirty, but you get the idea.
      Used to be known as 509chevelle
      Jun 2012
      Golden Valley AZ
      Thanks for the info, that is a great looking car!!!!
      John Rodko
      69 RS/SS Camaro.
      6.0L LQ4 to be TT
      Oct 2021
      I'm trying to put a magnuson tvs2650 under a 1970 Nova 2" cowl. Anyone know if this should fit?
      Sep 2017
      What do you guys think for a stock LS7 block down. Meaning rotating assembly and all is stock with cam, ported heads. Entertaining a supercharger. What can the LS7 safely hold with stock internals?
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
