    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 42
      Jan 2019
      1951 Ford F1 Build
      Picked up this 1951 Ford F1. Done a bit of work on it so far but here's the progress! Sorry for some of the sideways pictures!
      It's going to have a flat bed made to fit 2 motorcycles side by side, the motor i will put in it is an old chevy small block out of a c3 corvette because It's free. Going to build a box tube frame with '89 corvette suspension up front and a ford 9" in the rear with a 3 link set up. not sure which trans will go in it yet, but i'll let my available funds decide that later haha
Size:  250.3 KBName:  IMG_3571.jpg
      Got it home. The rear wheels kept locking up the whole way home!
Size:  236.1 KBName:  IMG_3601.jpg
      Stripping 'er down. built a simple wooden frame to hold it by the cab corners.
Size:  210.4 KBName:  IMG_3628.jpg
Size:  187.2 KBName:  IMG_3602.jpg
      Driver's side cab corner almost replaced. More updates soon!
      Apr 2018
      Ozarks
      Love those 50's Fords!
      Jan 2019
      Been off the grid, but here's a big update!
      Been a while since i've posted here, so i'll post my progress in a couple posts...
      Had to replace the rear cab corners, inside and outside.
Size:  106.4 KBName:  Back driver's Structure.jpeg
Size:  63.1 KBName:  Back Drivers Corner.jpeg
Size:  159.9 KBName:  Back Passenger Corner.jpeg
Size:  192.7 KBName:  Back Replaced Corners.jpeg
      Jan 2019
      Cab Nearing Completion!
      I decided to go ahead and buy the stock replacement floor instead of making one channeled to have the car sit low to the ground. With this floor i'll have the raise the rideheight a bit but it will be on the road sooner!
      I also decided to buy the Direct Sheetmetal 2" recessed firewall. it required some fitment. i needed to weld in 1/4" strip to make it fit the cab as it was too narrow. but even with that it was half a day to install.Name:  Firewall.jpg
      My Mig welder is brocken so i had to do TIG rosette welds to fill the spot welds. it was a pain in the ass but none the less i am happy with the result
      The floor fit in with no issues. it wasn't a perfect fit but it is good enough for me!
      Name:  Door Gap Check.jpeg
      I made sure the the door gap was perfect before i welded in the floor...
      Jan 2019
      Body Mount Mock Up
      Just wanted to share how i am doing the body mounds in the front...
      I made mock ups from cardboard and made sure they were fitting exactly how i wanted. I then layed each of the pieces out on the table next to a ruler and to a birdseye photo of them. I brought this into Fusion 360 and calibrated it and vectorized it. then i can export as a .dxf and shoot to the waterjet to cut them out and weld them up.
      Passenger side body mount
      Driver side body mount
      Fusion 360 vectorization...
      Jan 2019
      Beginning the Frame
      So the Frame is going to be a box tube frame built to fit the '89 corvette front clip i have in the front and a triangulated 4 link in the rear.
      Before i go buying material i want to model the whole frame up in Fusion 360 so i can create a cut list and make sure everything mates up as it should without any guess work.
      i Pulled the '74 sbc that i will be using for a temporary power unit. I will mount that motor onto the corvette clip sitting on wheels to take measurements so i know exactly how much i can lower the cab before i start interfering with the drivetrain. So that still needs to be done before i can finalize the frame model but here is what i have mocked up so far...
      Name:  Frame Rendering.jpg
      This is the 3D rendering of the frame
      Name:  Frame with Canvas.jpg
      i was able to use the factory drawings of the cab in order to rough out the geometry quickly
      Name:  Frame with Canvas.2.jpg
      Jan 2019
      Replaced the Front Corner (Again)
      After doing the rear corners, i knew i could do a better job on the driver's side front... so i cut it out and did it again!
      The door gap is not perfect but this truck is going to be driven, not perfect!
      Jonesboro, Arkansas
      I'm impressed that you've got a vertical mill! Welcome aboard.
      Carl Wilson
      Jan 2019
      Quote Originally Posted by minendrews68 View Post
      Thank you, Carl! Wouldn't live without one!
      Jan 2019
      Failed Attempts...
      Not every panel goes smoothly! I have had two failed attempts at this back panel and wasn't able to get the result i wanted. So i will move on and come back to it later...
      This was attempt number 2... it was close but i couldn't get the the welds planished back out to get the warpage out of the panel after welding. When i bought the car, there was a panel riveted over the back section to cover it up, so i will just throw that back on and worry about this panel when the list of other **** to do gets much shorter haha
      i began to finish out the rear quarters, mating them to the floor i installed a few weeks back. just needed to make a flange to spot weld to the floor. Got it tacked in for now and will finish weld soon (yes, my brother put a dent in my freshly formed panel ;) it gives it character)
      Jan 2019
      Frame Commencement
      I disassembled the corvette front clip that i'm putting in the truck to get some dimensions i need in order to CAD up the frame. i have a rendering of the frame finished. i will order material hopefully this week and get it started!
      This is the clip i am putting int he truck, it's from an '89 corvette. i originally thought the frame rail had to be horizontal in order to fit in but it turns out the frame rail needs to be 12 deg. facing up towards the front.
      i modeled it up with the new measurements. should be the final rendering. just need to make a cut list and order the box tubing
      This is the ride height i'm going for, will be a few inches lower than stock but nothing crazy. i want this to be a go anywhere vehicle
      Dec 2017
      Great project! Love where this is going. Keep it up!
      1951 Ford F1, 1967 RS Camaro, 1979 Firebird Formula, 1979 Trans Am/LS swap.
      Sep 2013
      sw Kansas
      What wall thickness are you going to use for the main rails?
      Jan 2019
      I'm using 1/8" wall tubing for the 2x4 sections. the middle 2x6 will be .187 because that's as thin as they go for 2x6
      - - - Updated - - -
      Quote Originally Posted by FormTA View Post
      Thank you! Much Appreciated!
      Sep 2013
      sw Kansas
      I used .125 on mine on the 2x6 but if I had it to do over, I would have used 3/16" on all the frame rails. I would still use 1/8" on cross pieces though. Mine has a stock 4.6 2v in it with a 5 speed. It has 8500 miles with no surprises but for no more weight than you add, I would have liked to have the added strength of the thicker wall material. I don't have access to solidworks or any software such as that so my design was not subject to F.A..
      Jan 2019
      I might go with 3/16 on the 2x4 as well to be consistent. The place i get material from only has 3/16 on the 2x6. Why would you have gone thicker, did you notice any flexing or anything to make you change your mind?
      Jan 2019
      Rear Suspension
      As i am preparing for the frame build, i am realizing all the **** i forgot to take care of that i need in order to build it! One of those being… the rear suspension. I have planned a triangulated 4 link rear with box tube lower control arms and dom round tube uppers.
      It’s not finished yet, still need to design the upper links on the housing, but it’s designed for a 40” lower arm and a 28” upper. I drew just enough data from the rear end to mock up the links. Getting ready to have these waterjet next week.
      Sep 2013
      sw Kansas
      I daily drive this truck. It has enough ground clearance to drive off curbs. It has ridetech coilovers on all 4 corners. 4 bar on the rear and a modified camaro front spindle setup on the front. The main reason for my statement was that the frame wasn't as rigid as I wanted before mounting the sheetmetal. There seems to be 2 thoughts on frame design: absolute rigid and flexible. The original frame on most trucks is designed to flex when doing normal duty. With me watching AME and the Roadster shop selling many frames that appear to be quite rigid, I'm speculating that for upper performance duty, less flex can be advantageous. From my drag racing back ground, I know that anything that flexes fatigues and fails. So is it worth a few pounds to shorten the life of the basic frame? If you have access to software that can answer that question, I'd like to know if I'm all wet.
      Jan 2019
      Thanks for the info! The truck looks great!!! If i were to make the frame from .125 wall it would weight about 288 lbs as opposed to 350lbs for 3/16 wall. The weight savings is only about 60lbs so it’s definitely worth it for me as i will be towing around large equipment with this truck!
      Jan 2019
      Rear Suspension Update
      Been working on the design for the 4 link. They’re pretty close. I made the brackets so they can all be waterjet cut, welded and fit nicely to the frame and axle/housing with good welding joints so they’ll be sturdy as hell. This is with a 40” lower arm and a 28” upper arm parallel to the ground at ride height. It’s got 3” bushings and 1.25” 10ga DOM tube for the control arms. Still have a bit or work to do but it’s getting there
