    Results 1 to 16 of 16
      Las Vegas, NV
      LS Parts, Intakes, Comp Cams, Forged Pistons, Rods, Aeromotive, Throttle bodies
      Have a bunch of LS /Vortec engine parts that will be not needing Prices include shipping from Las Vegas, NV (except crankshaft) I have a few complete LS3 and LS6 intake manifold setups: - Complete LS3 with seals, fuel rails w/ hold down bolts, fuel injectors w/ retaining clips, "gold blade" LS3/7 DBW Throttle body w/ bolts, MAP sensor and set of 10 GM intake mounting bolts (needed when converting from truck manifold)
      $550 for complete manifold setup
      - LS3 Intake manifold w/ port seals only, no map sensor, includes fuel rail, LS3 fuel injectors and set of 10 GM mounting bolts
      $425
      - Complete LS6 with seals, fuel rails w/ hold down bolts, fuel injectors w/ retaining clips, MAP sensor and throttle cable bracket ( LS6 dbc tb) and set of 10 GM intake mounting bolts (needed when converting from truck manifold) ( Have a couple cable throttle bodies available for extra $$)
      Part # 12573572
      $450 for complete LS6 manifold setup
      - LS2 " Silver Blade" Throttle Bodies GM# 12570790
      I have (2) available
      (1) stock unported (1) has 3/16" hole in blade from tuner for idle
      Pricing:
      Stock TB - $220
      Stock TB - $200 (w/ drilled blade)
      - LS manifold (car intakes) GM mounting bolts (set of 10) needed when convert truck / Vortec to car intake $20/ set
      - LS1 Forged Pistons and 5140 CNC Beam connecting Rods
      Probe Industries " SRS" Sportsman Race Series Forged Flat top piston set 3.00cc
      Part# 14217-003 w/ rings
      for 3.902" bore ( .004" overbore on LS1), 3.622" stroke w/ .927" floating pin
      and
      Probe Industries CNC Beam 5140 Connecting Rods w/ ARP Wave Lock Bolts
      Part #11662 with bronze bushings
      low usage (see pics)
      $480 for forged pistons & rods
      -LS1/ LS6 GM bolt on Throttle cable Brackets w/ (2) mounting bolts
      $25 ea.
      - New Set of (16) LS7 Connecting Rod Bolts
      GM part # 11609825
      $120 for set of 16
      -Comp Cams LSR Rectangle Port (large displacement) 3 bolt camshaft
      part # 54-473-11 specs: 247/263, .624/.624 114 lsa
      http://www.compcams.com/Company/CC/cam-specs/Details.aspx…
      low miles
      $300
      - Gen V 6.2l L86 Crankshaft
      part# 12623492
      will need to be turned/ polished on rod journal
      $80 (plus actual shipping cost)
      - (2) used Aeromotive A750 "Tsnami" electric fuel pumps EFI
      both will need to be sent in to Aeromotive for rebuilds
      make offer $$
      -LS Billet Ignition Coil Relocation brackets w/ mounting hardware
      for LS2/3/7 coils
      places coils towards center of valve cover
      $50
      -LS3/7 new take off round ignition coils w/ mounting brackets
      no harnesses
      $130
      - LS3/7 5.3 , 6.2 used square ignition coils w/ mounting brackets & harnesses
      $130
      -Speedway Motors LS F-body Billet Alternator relocation (high mount) bracket
      $85
      - misc LS / Vortec stock valve cover sets available
      more pics here: https://lasvegas.craigslist.org/pts/...765079636.html
      pm/call/text (702)677-4085
      Aug 2010
      Richmond , Tx
      Country Flag: Philippines
      Pm sent
      69 Camaro LS7,T56 magnum F Baer brakes ridetech 4 link Forgeline wheels yada yada yada. Never finished
      17 Grand Sport
      Las Vegas, NV
      Quote Originally Posted by jamminj007 View Post
      Pm sent
      pm replied
      Feb 2017
      New Mexico
      PM Sent
      Las Vegas, NV
      Quote Originally Posted by KAN KAN Speedshop View Post
      PM Sent
      pm replied
      thanks
      Price on the pedal
      Las Vegas, NV
      Quote Originally Posted by IMPALAMAN1 View Post
      Price on the pedal
      I have them listed in separate ad, for some reason, I can't edit my ads??
      Clayton Machine Works "Muscle car" series Mechanical Throttle Pedal assembly
      new in box
      Part # MCP-P1
      $175 shipped
      Clayton Machine Works "Muscle car" series DBW throttle Pedal pad
      new in box
      $80 shipped
      May 2017
      I will buy the New LS7 Rod Bolts from you. 408 644-4610
      Las Vegas, NV
      Quote Originally Posted by C Presley View Post
      PM sent
      Las Vegas, NV
      bump
      Las Vegas, NV
      bump it up
      Apr 2010
      Los Angeles
      $130
      How much if i make a trip to Vegas to pick them up?
      Las Vegas, NV
      Quote Originally Posted by Mofoe73 View Post
      $130
      The used set of square ones are sold (I can't edit my ad for some reason?)
      I just have the new set of round ones
      $100 picked up
      Jeff
      Las Vegas, NV
      The LS3 and LS6 intake manifold setups are all sold
      Las Vegas, NV
      I have one LS3 and a LS6 intake manifold setups available again
      Las Vegas, NV
      LS3 intake manifold setup and single Clayton pedal pad are SOLD!
