      Jan 2017
      pickering ontario canada
      Ac belt slip help !?
      Hey guys.
      71 LSA
      700hp
      Vintage air
      kwik performance tensioner.
      The pullys for my car are all
      4 rib.
      The ac pully by kwik
      who I guess has a contract
      w/ vintage air
      is a 6 rib...
      so...
      under hard throttle i throw my
      belt off.
      I called kwik. Guy seemed eager
      to help...
      said couple guys have and this issue..
      said look into a shorter belt
      or a gm stretchy belt...
      best he can do...
      wtf...
      what other options do I have?
      gotta have ac and I obv want
      to go up the road sideways...
      1971 chevelle LSA 700hp -
      Mountain Springs, Texas
      Gates has a tool to check pulley alignment. Sounds like they are off. I would swap it out for a cast Holley mount. Mounts made of flat plate can easily flex under load. Not a fan....
      https://m.youtube.com/watch?v=s9Jd7i_sIwk
      You have a four rib belt on your supercharger? That’s quite small imho...
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jan 2017
      No. It’s not an alignment issue...
      I’m not understanding why my ac pully
      Is 6 rib but the connecting pully is 4.
      There’s no guide on the ac pull and the 4rib belt
      Jumps or falls off the edge of the pully.
      Nov 2016
      Sulphur, La
      Could it possibly be throwing the belt when you let off the throttle?
      How do you know it is not an alignment issue? Lots of four rib belts running on 6 rib compressor pulleys without issue. It is the most common setup....
      Don
      I live in Alabama and I don't have AC...You're in Canada...YOu need AC when it is 70 degrees? I know...not helpful...Carry on...
      My bets are on a pullet misalignment.
      Instagram @projectgattago
      Dr. EFI
      Jan 2017
      Ok fair. It could be misalignment..
      The way I was lead to believe was
      Bc of the 6 rib to 4rib plus the
      Power of the set up....
      I will look into that.
      Took is pricy. Is it common to
      Rent these?
      Thx guys
      Buy the tool and then sell it on eBay when you are done.
      Don
