      Sep 2018
      Idaho
      GM RamJet 350 wiring
      I have a RamJet 350. I have a white wire that I do not know what it hooks up to. A wiring loom that has a heavy read wire (from the battery through a fuse), a purple wire labeled ignition, a gray wire labeled analog tachometer, and an unlabeled white wire. Does anyone know what the white wire goes to?
      Mountain Springs, Texas
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      El Paso, Texas
      I found this in the manual. Maybe this is it? Didn't specify color codes.
      14. You will also notice two tachometer outputs from the harness, tach1 is for a standard negative side of the coil driven tach.
      Tach2 is for digital tachometers; this is a 0-12 V square wave output. Select and connect the proper output for your application.
      Sep 2018
      Idaho
      Thanks for the information.
    Tags for this Thread
