    Results 1 to 12 of 12
      Apr 2008
      La Verne CA
      Piping fabrication finally completed!
      I've finally got my hot and cold sides fabricated. Any good recommendations for a local shop for ceramic coating work here in SoCal, preferably in the Inland Empire?
Size:  142.5 KBName:  IMG_20180816_121748653.jpg
      Orange County, CA
      Embee in Santa Ana. Nice job on your car too.
      Apr 2008
      La Verne CA
      Thank you!
      Feb 2011
      Looks great!
      Mar 2011
      San Bernardino, Ca
      Try Young Guns in Rancho Cucamonga for coatings
      Apr 2008
      La Verne CA
      Quote Originally Posted by tigerracer View Post
      Thank you!
      Jun 2017
      Nice build! I’m building the same thing 69 with twin turbos what size engine and turbo?
      Apr 2008
      La Verne CA
      Quote Originally Posted by 1Bad Ls View Post
      Thanks! Motor is a 383 with Dart Pro 1 heads and FAST efi. Turbos are Turbonetics T04B (60mm) and running a two-stage boost controller. I plan to run street trim around 8-10 psi and my track tune is 15 psi. Made about 750HP/750tq prior to reworking the hot side to flow better, I anticipate putting down around 800 which is about as much I want to throw at the original GM block but should be enough power for the street. How about you?
      Mar 2011
      Ca
      looks good, I'm about to start my hot and cold side plumbing.
      May 2011
      That's really nice I wish I had the skills to do that fab work...
      64 F-85 post car Resto-Mod project-my RV when I retire
      Jan 2011
      Charlotte, NC Region
      Looks good. Curious on your plan surrounding the brake booster / master. Piping looks a tad tight back there.
      Apr 2008
      La Verne CA
      Quote Originally Posted by mklinger View Post
      Yes the downpipe interferes with the stock location. Putting in a reverse swing mounted Wilwood setup with the master cylinder inside the car with a remote fluid reservoir located on the firewall. Brakes are Wilwood four pot on all corners and currently manual. In the future I might consider going with a hydra boost if I can make it fit.
