Results 1 to 20 of 27
Thread: 78 Fairmont Project
12-04-2005 #1
- Aug 2004
- McDonough, Ga
- 24
78 Fairmont Project
Well, I've been able to make a little progress on the Fairmont. Here's what we started with. A 24000 mile car from southern California. We added the Welds after we first got it. Looked good pimping around with the original six in the car.
So far I've gotten the car disassembled and painted the engine bay.
The rearend is also assembled and mocked up under the car. I'm putting a Steeda 5-Link rear suspension in the car along with D-spec Tokico shocks and 390-430 MM rear springs. So far everything has fit, except the chassis mount for the panhard bar. I'm going to have to cut the Steeda piece apart and make new bracing to run to the other frame rail. The Fairmont gas tank and straps are in the way not allowing the piece to sit in the proper location.
The Cobra rear brakes fit great on the NorthRaceCars.com brackets. The axles were sourced from them as well and are nice pieces.
The front suspension is made up of mostly Maximum Motorsports pieces. A Mustang K-member was installed along with some MM tubular lower control arms. Next to install are some 94 Mustang spindles and some Cobra brakes. There are Tokico D-spec struts as well as 375 springs on a MM coil-over kit. The stock manual steering rack has been replaced by an 03 Cobra unit and MM steering shaft.
Some Bullits were test fit as well. These have a set of 255/40-17 Kumho's. They are a little too short for my taste.
Tonight we mocked up the front suspension. The MM coil overs worked out fine on the D-spec struts. We also blasted and painted the 94 spindles. Next is a new set of hubs for the car. These are pretty ratty and must have a bunch of miles on them. I apologize for the pics being so dark.
Also tried the 255/40 tire and wheel combo on the front. I think this is the size we're going to shoot for. The fender is just sitting on the car to get an idea of how the wheel looks. It also looks like we may need to get some crash bolts for the strut/spindle to be able to hit ~3* of camber for the track.
Got the Master Cylinder from Napa tonight. It's an 85 Lincoln Towncar unit with a 1" bore. The best part is it's aluminum and only $16. Unfortunately they didn't have the booster in stock. I ordered a 94 V-6 Mustang booster for the car.
Lots more to do. It's looking like the car will also get a TKO600 behind the 347 instead of the FMS World Class box that I was planning to use.
CurtisLast edited by O&C Racing; 12-04-2005 at 05:15 PM. Reason: I just can't spell :)
