      FiTech "ECU no response"
      I am having trouble getting my FiTech up and running. Ford small block, FiTech EFI, MSD 6. The handheld is working but when I go to initial setup I get "ECU no response". I have a separate wire direct to battery for the +12 volts, the white wire (key) has +12 volts in the on and start position, also tried a separate ground wire from battery to throttle body. The shop that built the motor dyno'd with the FiTech so I am thinking it must be something I have done or not done. Any suggestions?
