    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 116
      Jan 2016
      Chino Valley, AZ
      Quote Originally Posted by samuel642000 View Post
      Sounds eerily similar to mine, ended up being head gasket failure.
      oh damn. how did you discover it was the head gasket after all?
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Nov 2018
      Quote Originally Posted by frink84 View Post
      Just a guess... Trying to decide what route to go, leaning towards ls swap since I'll want to refresh the 5.0 at this point. Makes more since to go ahead and swap.
      Oct 2018
      Phoenix, AZ
      Sorry about the bum motor. I'm wondering if I should have LS swapped from my 351w. I've got a boatload of money in that build and the LS has waaaayyyy stronger mains anyway. Screw the brand loyalty. Cheap(ish), reliable, and V8 is all that matters. Plus you'll be saving weight so there is that.
      Nov 2018
      hah yeah thats, uh a hell of a sign there. you'll get no hate on a LS swap here, engine swaps are what hot rodding was built on. engine loyalty was built by the oems in the 60's.
      Lol yeah, I have zero brand loyalty as long as its the best bang for the buck and I like it, all is fair. I'll probably throw gaskets in it and drive it while I collect parts for the swap.
      Exactly, on the cheapish and reliable side, weight savings will occur if an aluminium block is used, but if going with the iron block, not a lot of savings to be had.
      Southern California / Maryland
      chocolate milkshake of death ---
      1966 Chevrolet Chevelle 300 Deluxe 350 / 350 auto
      1968 Dodge Charger SRT8 6.1L Hemi / 6-speed
      1964 Dodge Polara 8-71 Blown 440 / 4-speed
      1998 Toyota 4Runner SR5 3.4L / 5-speed
      2013 Dodge Challenger R/T 5.7L Hemi / 6-speed
      Jan 2016
      Chino Valley, AZ
      finally got my haul of parts from my parent's house over the holiday break. the parts consist of a MM Panhard bar, MM standard duty torque arm, MM Clutch Cable/Quadrant/Firewall Adjuster Package, and a pair of Stoptech slotted brake rotors for a SN95 cobra rear brake setup.
      I also have a pile of other unused SN95/Fox suspension parts that came in the haul that I'm not using. Selling these gives the Ghost more funding! (PM me if interested: Hawk HPS rear pads for sn95 cobra, MM steering shaft for 94-04, MM torque arm springs with isolators, and a MM SS front hose kit for SN95)
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Mar 2018
      la mesa, CA
      This puts a big grin on my face! I can not wait for install day.
      Follow my Instagram
      And my build on here
      check out Opentracker Racing Products
      Mar 2014
      Mesa, AZ
      Agreed, nice haul! Makes me jealous haha
      Nelson
      Jan 2016
      Chino Valley, AZ
      Started installing the PHB. Got stuck at the axle mount. The Maximum Motorsports provided bolt was too short. It measured at 100mm, the instructions listed 112mm, and the current instructions on the website listed 117mm. I exchanged some emails with Jack Hidley over at Maximum Motorsports, who let me know that the bolt did change in 2010 so my PHB was old. We then checked the axle mount, which was current. All these parts were NIB, so I dunno what went on there. Long story short: MM is awesome and is shipping a new axle mount bolt to me, free of charge.
      The OEM and current MM bolt next to eachother. I could technically use the OEM bolt for mock-up, but felt that having the threads in the RCA bushing would be a bad thing, so I'm waiting for the new bolt.
      I also verified that there were no updates to the torque arm for me to worry about.
      In addition to all that, sold a grip of parts I wasn't going to use, so I bought a Moates Quarterhorse and an Innovate wideband o2 sensor. Gonna get all nerdy on this thing.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Jan 2016
      Chino Valley, AZ
      Put in a few hours on the Ghost over the weekend.
      Got about 80% done with the PHB installation. I must say, MM's instructions and tech support are killer. Multiple responses on a Saturday, unheard of. The longer bolt showed up, then I had to find a 1/2" and 5/8" drill bit to drill holes in the subframe. Then I had to go back to the store to buy a drill with a big enough chuck for the 5/8" drill bit. Fun times and new tools! No pics, but I'm on the home stretch, which requires re-installing the coilovers, settling the suspension, then setting the car back on jack stands at ride height to install the bar level and adjust to get the rear centered.
      Because I was waiting on the bolt and other parts showed up, I dove into the Innovate Motorsports 3918 MTX-L Plus Wideband Gauge install. I had installed a trio of VDO gauges (water temp, oil pressure, voltage) below the radio over 10 years ago. I figured I could pop the voltmeter out, install the wideband, hook up power, and go. No dice. Pulled the radio/gauge surround and realized I did **** sloppy 10 years ago. Badly soldered wires with electrical tape instead of heat shrink, sketchy grounds, hard wired... ugh. So I pulled EVERYTHING, including the wiring to the sensors, and built it right, with good wire length, stress relief, crimped and heat shrunk connections, the works! Innovate recomments a relay for gauge power so I did that for all the gauges, and added a weatherpack connector (ordered a $28 crimper kit off Amazon that worked fabulously) for servicability.
      Ended up with this:
      All gauges worked great and the car idles at flat 13 AFR. Woohoo.
      Also been playing around with TunerPro RT in preparation for the Moates Quarterhorse installation. I'm using the A9L2 from http://www.efidynotuning.com/ as a base and I think I have a handle on it. Curious how my first startup will go with that.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Jan 2016
      Chino Valley, AZ
      guess it didnt like my image
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      McKinney, TX
      Step bit next time, they work amazing.
      89 Mustang "Box Wine"
      Jan 2016
      Chino Valley, AZ
      I've used step bits before, however when drilling the pilot holes I found that the frame was double-thick in a few spots. Didn't want to make huge holes. I needed a powerful corded drill anyways (at least thats what I told the wife...)
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Apr 2015
      SoCal
      Pretty jealous of that MM stuff your car is getting. When are we racing these things?
      CAM-T Autocross Fox Mustang
      LX mustang autocross on the "cheap"...
      1953 PickEmUp
      1953 Chev Pickemup
      Mar 2018
      la mesa, CA
      Quote Originally Posted by LERM View Post
      When we can convince our better half's to move to Texas!
      Follow my Instagram
      Jan 2016
      Chino Valley, AZ
      Quote Originally Posted by Project Bike Truck View Post
      what Danny said hahaha.
      Anyways, got some time in last night. After a lot of debate and measuring, I'm just converting the existing MAC exhaust to dumps. I really like the sound from that system, its well past being paid for (bought over 10 years ago...) and I'd likely spend more on building a new exhaust vs using what I have. So I pulled out the Flowmaster 40's and spent some time with the cutoff wheel to create the following:
      Got it under the car and the turn downs hit the axle. Strange. Pulled those off and got the mufflers into place. Looks like the MAC stuff puts the mufflers way far back in the muffler pocket. The double-edged sword of the MAC system is that its multi-piece with a bunch of ball and socket connectors for maximum adjustability. But that hurts fitment. You can see that there is a good 6-8" of room in front of the muffler to move it up. Also, the driver side muffler's tailpipe started turning up RIGHT at the weld so it looks a little weird at the moment.
      Once the car is back on the ground and I finalize the PHB, I'll start on the torque arm. Then with all that done (hoping that the exhaust doesn't cause any issues with that installation), I will take it to an exhaust shop. I'm thinking delete the ball & socket ahead of the mufflers, move the mufflers towards the front of the car and get them tucked up nice and tight, and put turn-down tips on them.
      I started the car as-is with the shop closed, and it was louder than before (but then again I've never started the car with the doors closed before) but it is MUCH more liveable than the Flowmasters.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Jan 2016
      Chino Valley, AZ
      I finalized the PHB install last night. The bar was level by default and the axle measures out to within 1/16" centered to the chassis. thats an important metric for the coming torque arm install, so I was happy that I didn't have to tweak anything. THeres something to be said for a car that you know the entire history of!
      I drove it around the block to settle the suspension before installing the PHB (per instructions), and got to watch the wideband reacting to how the car was running. While it was stumbling at >3000rpm, the AFR is sitting in the 14.5-15 range. Then the car basically catches itself, AFR drops in the 11.5-12 range, and it takes off. Repeat. I don't exactly know what it means, but to me that means fueling issue. I'm going to resistance-test the injectors when I get some time, and order the 255lph pump to install while I have the car back in the air for the torque arm. For data's sake, idle is around 13, while cruise is 14 or so.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Jan 2016
      Chino Valley, AZ
      New fuel pump showed up early, so I got all kinds of excited and dropped the tank
      Installed the new pump into the hanger but the strainer wouldn't stay on.
      I contacted customer service after going crazy with the calipers
      Turns out its missing the little metal doohickey, should look like this
      Now I'm working with Carter technical support to get a new one sent out. Seems to be my luck of the draw with this thing...
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Jan 2016
      Chino Valley, AZ
      So I got the new fuel pump installed. After a LOT of back and forth, Carter's product manager of fuel systems sent me a new strainer.
      Old pump and debris that came out of the pump/strainer
      Collection of strainers, old on top, good one on the bottom
      The new pump is shockingly quieter than the old one. Like, had to listen for it priming, and even checked the fuel pressure at the rail to ensure it was running. The car started on the first try.
      I drove it around a bit and it.... still acts funny. I videod the AFR while going through the gears. It basically leans through first then figured itself out and adds fuel for the rest of the gears. This is only when getting on it, otherwise it always leans out.
      https://youtu.be/m5OnYB6h2Gw
      https://youtu.be/0VhjUZKpgcU
      I think at this point its time to pay attention to the engine side of the fuel system, aka testing the injectors and paying attention to the regulator bleed down after shut-down.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
      Jan 2016
      Chino Valley, AZ
      I may have had a major breakthrough last night. Started pulling the upper intake manifold to go after the injectors for some resistance testing, and noticed the TPS sensor looked a little... iffy. The ground is nearly pulled completely out of the sensor! I ordered a new one from Rockauto and it shipped from within Texas so it should be here shortly. Really excited that this may be the magic bullet.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
    Tags for this Thread
