    Results 1 to 3 of 3
      corona,ca.
      Adjustable Prop valve with cpp prop valve
      Hi all,I'm in the process of installing my wilwood manual mc.
      On my 72 chevelle,c5 vette brakes
      The question I have is do I use my cpp disc/disc frame mount prop valve with the Wilwood 260-8419 Adjustable Proportioning or do I remove the cpp one from the system and use a distribution block with the adjustable prop valve?
      Thanks.
      72 chevelle.
      Beach Park IL
      I like adjustable prop valves and you should never have two in line.
      Donny
      corona,ca.
      Thanks.
      Removed the factory prop valve and will run lines to a brake tee.
      72 chevelle.
