    Results 1 to 3 of 3
      69 camaro 4 link install squaring things up?
      I installed ridetech front suspension and have bracket's tacked on rear end and centered in the wheel well front to back and side to side.
      Question is as I started stringing from the front to rear I notice that the front wheels have different clearances from the sidewall of the tire.
      Is it possible that the front sub frame moved slightly towards the passenger side? I still have some clearance and heard of using different bolts with a smaller head.
      What is the proper way to square things up? Can it be done in the garage or more of a alignment rack type job?
      Did you have the front end aligned? Tire clearance to the fender will be affected by camber, assuming that is the clearance you are referring to.
      Don,
      I haven't had it aligned yet. Many years ago I hit a curb fairly hard, didn't bend anything but did needed a trip to the alignment shop.
      I will keep moving forward with the rear suspension install then get it to the alignment shop.
