    Results 1 to 20 of 100
      Aug 2021
      Wondering same thing. how hard was the clayton gas pedal cover to mount to the LS pedal unit? Can we get a pic of the back of that pedal so we can see how it mounts to the LS pedal part?
      Sep 2013
      Oakley, CA
      Quote Originally Posted by linenoise View Post
      Unfortunately I do not have the car with me, it is currently in the interior shop 6 hours away. But here is what was done to make this work.
      I had to swap the DBW pedal from the 2014 Camaro with a 2007+ Corvette pedal from PSI Conversion ACC-1007. This part bolts up to the firewall like a stock 70 Camaro pedal.
      I removed the old style pedal cover and put Clayton Machine Works TA-206-DBW pad on to replace the pad that comes with ACC-1007. They both use pin and E style clip to secure the pad onto the assembly.
      You do have to swap the wires from the ECU to match with the new DBW assembly. I have to double check but if I recall correctly, I swapped dark blue and light blue. there are write ups on the wire swap for the 07+ Corvetter DBW.
      69 Camaro LS3/6L80e
      70 Camaro RS LS3/6l80e
      74 Nova 434 SBC
