      Sep 2015
      Orange County, CA
      Rear shoulder seat belts for '69 Camaro
      I purchased front and rear 3-point seatbelts from Camaro Central for my ‘69 Camaro but I don’t think the rear seatbelts are going to work with my package tray that I got from The Shop LLC. Any suggestions on other options? I am not running a roll cage and want the option to safely have back seat passengers.
      Nathan
      1969 Chevrolet Camaro • Documented on Auto LineageBuild Thread
      Nathan,
      WOW !!
      Hopefully you bought Morris Classic Seat belts.
      By looking at the picture of the rear panel in the trunk area , I think
      you will be able to install our seat belts.You will need to remove the
      speaker & mounting plates. Mount the bracket to the body and drill
      the hole thru the shelf panel. The bracket fits up against the shelf panel
      and around the 6x9 speaker hole.Mount the bracket and reel then reinstall
      the speaker assembly. you may have to trim the speaker mounting plate
      but I think you can do the install without too much altercation.
      Call us if we can help. 864-987-0032, Billy
      Feb 2014
      Bend, Oregon
      If you do get this figured out, make sure and take some pictures during the install. Unless Morrisclassic has some to share? I'm trying to figure out eventually what I'm going to do, and I'm using the same The Shop LLC sub box and 6x9 rear speakers. Haven't purchased or decided on the rear package tray.
