- Sep 2016
- 36
Setting up mechanical linkage for T56 magnum
I'm setting up a T56 Magnum behind a SBC -- quicktime bellhousing, stock Z-bar linkage with spherical rod ends, and mcleod RST clutch. I just test drove it and it feels great but the range of clutch pedal for engagement is quite narrow -- maybe 1/2" from starting to engage to fully engaged and the pedal pressure is medium, certainly heavier than the "lighter than stock" that mcleod describes.
Any suggestions on adjusting either the clutch engagement range or the pedal weight?
Thanks!1970 Chevelle - CA car, 45k orig miles
427 Shafiroff, T56 magnum, 12 bolt 3.90
Rick's restomod tank, ZL1 pump
