      Mar 2016
      Any 727 or 46RH experts around ?
      Guys,
      I'm looking for someone that knows the 727/46RH trans operation really well.
      For a while I've been wanting to make a full solenoid control valve body for these transmissions.
      I am able to program a microcontroller to control the shifting, which I already do with my own 46RH (electrical engineer), but of course gears 1 to 3 are still hydraulic.
      Could use the same solenoid type as the 46RH uses but for all gears and the lockup.
      I have access to CNC machines so I am able to fabricate a new valve body to suit the new application.
      I'd make it with two control modes selectable from a dash switch. One mode full auto up and downshift and mode 2 with paddle shifters full manual control.
      Sensor inputs from engine rpm, manifold vacuum/pressure, car speed, throttle position.
      Anyone out there willing to help out ???
      Feb 2016
      Lawrenceville, IL
      You may want to reach out to the guys at A&A Transmission (317) 831-3066. They only do Chrysler transmissions.
      visit us on the web at www.bowlertransmissions.com
