      Jonesboro, Arkansas
      Rubber to steel ..
      I've got a radiator overflow tank that has a 1/4" stub coming out of it. From the radiator, the hose is 5/16". I have to use the 5/6" because that's about as small as I can get and still get it over the radiator tube. But that leaves it loose at the overflow end. I've tried just about everything I can think of to make this work. I've used two plastic wire ties pulled tight then two small SS type screw clamps and I can still pull the rubber off the 1/4" end. Now I'm thinking I may need some kind of adhesive that could fill some of the gap. Do you guys have a idea?
      Carl Wilson
      Jonesboro, Arkansas
      Just went to Advance Auto, got a piece of 5/32" vacuum tubing. Put a piece about 1" long on the overflow and forced the 5/16" piece over that. Going to clamp this and see how it does. You can't tell it's done this way other than the small bump on the end. Here's for hoping.
      Carl Wilson
