      Jan 2014
      Wilwood Mustang II Pro Spindles
      http://www.wilwood.com/Spindles/Spin...temno=830-9807
      Has anyone here used these spindles? I have two cars with MII style suspensions which use the standard 2" MII drop spindle. These Wilwood spindles move the upper ball joint location a half inch taller which should improve camber gain. Other than that I'm not sure what advantages or disadvantages they offer. I'd love to here from someone who has used them or understands what other changes come with them. And what brakes you used.
      Rich
      Rich
      1962 Mercury Comet, 32V Cobra engine, 5-speed, 8.8 rear, custom suspension
      1965 Ford Mustang, supercharged 5.0 EFI
      Orange County, CA
      Wilwood makes brake kits that'll bolt right on to the spindle. Art Morrison helped Wilwood with the new spindle design. AME uses this spindle on a lot of their performance chassis. Here is a page from the AME catalog about the spindle,
      New Premium Quality Forged Steel Assembly
      Is The Perfect Replacement For Mustang II
      The venerable Mustang II front spindle has been a staple in I.F.S. setups for street rods and street machines. But as anyone who has had to use the OEM Mustang II
      unit, and aftermarket copies knows, there are shortcomings. That’s why AME has collaborated with Wilwood Engineering in the development of this new spindle that should prove to become the standard of the industry.
      It’s made from a high strength steel forging and heat-treated to
      provide increased levels of
      durability. The forgings are CNC-
      machined to exacting tolerances, and incorporate important design features. The unit is taller than the OEM Mustang II to provide improved geometry. There is a greatly reduced roll center migration. And the unit
      has been designed to accommodate radial
      mount calipers and rotors up to 14"
      diameter. A bolt-in retrofit for existing
      Mustang II units, it’s the answer for anyone
      wanting to equip their ride with serious
      braking power, while improving handling.
      Jan 2014
      After more research on these spindles I decided against them. The KPI is three degrees higher than a Mustang II spindle which really hurts. Furthermore the overall height is only a half inch higher and it cannot readily mount GM metric calipers. So, I bought Howe Racing 1" taller upper ball joints to help my situation.
      Rich
