    Results 1 to 20 of 21
    Thread: Shorty headers?
      Milwaukee, Wi.
      Shorty headers?
      Can anyone suggest a good sbc shorty header for my 69 nova? The Hedman's look great but they don't fit with p/s box? Any experience?
      Thanks, Steve
      Nov 2002
      Georgetown,TX
      Try Sandersons.
      I dont have shortys...but I can say that my long tube 1-3/4" dougs headers fit just fine with my power steering box. Oh yeah, its a 69 nova as well.
      Just a thought on shorty headers:
      They have all the disadvantages of headers (leaks, short life span, re-routes of exhaust, possible fitment issues, etc.) with none of the performance advantages. In short, they aren't worth the headache of installing in a car that already has a working exhaust.
      That said, if you are building the car and don't already have an exhaust setup and are looking for something that is better looking than cast iron manifolds, shorties can do that. If you are looking for better than oem exhaust flow, you need to look for longer tubes.
      A good source for shorties are street rod dealers, like Sachse Rod Shop.
      jp
      ​John Parsons
      Nov 2004
      Patriot Clipster
      Check out Patriot Clipsters. They are "shorties" by definition I guess, but aren't as short as your typical set. Also they are angled back towards the firewall allowing more clearance around your PS pump.
      They come in Ceramic Coated as well as Bare Metal.
      Patriot is a Pertronix company.
      Pertronix
      Get Blended
      Nov 2002
      Georgetown,TX
      You guys are confusing shorties with intermediates. Most street rod shorty headers won't even clear our car's crossmembers.
      Intermediates have proven to be decent power producers. Shorties have not.
      Milwaukee, Wi.
      Yes, intermediates are exactly what I meant! I have been looking at Hedman Elites, Hooker and the Patriot clipsters. The Hedmans look great with 3/8" flanges and 14 ga tubes. I was hoping to get some real experiences with any of these.
      Thanks, Steve
      Agreed: mid-length headers have been shown to increase power.
      jp
      ​John Parsons
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by blown69nova
      Thanks, Steve
      Manual trans or auto? I think the Sandersons are the only intermediate that will clear the clutch Z-bar. F-body cars might be different but that's the case with an A-body. I've used Sanderson intermediates on my former 68 El Camino with 468/700R4 combo and liked them alot.
      Check out their ball & socket exhaust flange set-up,,much better than the standard three-point.
      Tallahassee, FL
      I picked up a set of big block coated Patriot Clipsters from http://www.carshopinc.com. Only $259...about $40 cheaper than Summit.
      I haven't installed them yet, but they look nice. I'm pretty sure they
      won't work with a stock manual clutch. I'm using a t-56/hydraulic clutch, so I think they'll fit ok.
      Jason
      SC
      yes, they will work with the stock clutch set up. I have a pair on my 69 BB Camaro.
      Mantorville, MN
      I bought the Hedman Elites, which are very similar to the Patriot Clipsters, except they're available with 1-5/8" tubes, where the clipsters are, I believe only 1-1/2" (or maybe that was the sandersons I was looking at... just bought them 3 weeks ago, you'd think I could remember )
      Nov 2004
      NW Arkansas
      Quote Originally Posted by Derek69SS
      I have the same headers....very nice product!
      KENNY DAVIS HOTRODS
      May 2000
      The Patriots are 1 5/8" tube.
      I need some mid lengths for my '70 Nova. The Hookers I have on there now just hang way to low. I'm just not sure if the mid lengths will work with my square port exhaust.
      Nov 2004
      NW Arkansas
      Quote Originally Posted by MarkM66
      mark I got my midlengths from http://www.jet-hot.com/ you might be able to call them and see if they have a header available that will work for your application.
      KENNY DAVIS HOTRODS
      Mar 2002
      Redwood City, CA
      Take a look at the Hedman 68600 headers. I have the 68601's on my camaro, and they work great. The are intermediate length, and have great ground clearance. They do not clear the manual z-bar, but they do clear the steering box on a first gen. The tubes are 1 5/8 and clear the straight plugs pretty well. I believe they are available coated as well. Mark, I have stock square type exhaust ports and they work fine with them. I use the Earl's Pressure Master seals on them though, and that really helps them to not leak.
      Allen Ortega
      May 2000
      Quote Originally Posted by Travis B
      I'm actually worried about where the header meets the head. My ProToplins have pretty large square ports. I need to get a measurement on them to see if a 1 5/8" tube will cover.
      May 2000
      Quote Originally Posted by zbugger
      Thanks, I'll look into them. I actually emailed Hedman about these headers. Their response was "we don't offer headers for non-stock heads" so they weren't much help.
      Mar 2002
      Redwood City, CA
      lol... I checked them on my Sportsman II's and they look to fit fine. The only time I think you'll have a problem is if you have raised ports. Most aftermarket heads don't differ too much from stock measurements until you go into the raised port stuff specifically for racing.
      Allen Ortega
      i had some sanderson. nice thick flange never leaked.
