      Jul 2016
      Holley accessory drive 20-137 LS3
      I was reading the instructions for my Holley accessory drive set-up on my crate LS3 engine and it states trimming may be necessary on the water pump bosses as well as another area. The LS engines use a type 3 water pump as per Holley. Any of you guys have to trim your water pump???
      Metamora, Illinois
      I don't remember having to trim mine. I wouldn't worry about it. Just mock it up and trim if needed .
      Jul 2016
      Quote Originally Posted by rocketrod View Post
      OK, thx.
      Jun 2010
      Deployed
      I'm using the C6 pump from an 08 and no trimming.
      1970 Camaro/DSE build
      Jul 2016
      Thanks.
      Jun 2011
      Brooklyn, NY
      I run lsa pump on one car and gen5 camaro pump on other, nothing to trim
      El Paso, Texas
      I used stock C6 accessory mounts with the Holley AC Sanden mounts and I did have to grind on the water pump bosses. The LS3 was from a 2008 Corvette. There was some interference on the lower bolt for the Holley AC bracket when it came time to install it. I ground down quite a bit and was still having issues so I did the second option that Holley recommended and removed the water pump to install it and it went off without a hitch. I should have done that in the first place.
      I also had to grind down a couple of place on the water pump so the belt wouldn't rub on it. I t was close and might have cleared but it was easy to grind them down a little. The locations are listed in the instructions and I just followed that. Hope this helps.
      Alex
