      May 2017
      delaware
      1964 mercedes 220b track day suspension design
      I'm building A '64 mercedes 220b Fintail track day, autocross, and any other motorsport I can sign up for. The car is 2900 pounds stock. Im installing an all aluminium DOHC 5.0 (303.5 cu/in) mercedes engine that is at least 100-150 lbs lighter than the stock iron I-6. The front suspension has pretty good geometry from what i can tell but will need some tweaking to get the anti dive and roll centers right(and adjustable). Its short and long arm design, Approximately 17" lowers and 10.5" uppers. The control arms bolt to the subframe on cross shafts which are parallel to the centerline of the car as far as i can tell. I haven't leveled and plotted the centerlines yet but i should be able to shim the lowers for anti dive. One issue is it has king pin knuckles, ive read that they dont handle brake torque as well as ball joints but i don't know. I'm thinking that i will change the spindles to the next gen mercedes bits which have bolt on steering arms, with custom control arms and shorter steering arms to suit the rack and pinion ill be swapping to. the rear is a low pivot swing axle. it has level lower control arms(18 inch center to center i believe) parallel to the cars centerline with spring perches just forward of the axle mount on the arm. My plan is to use the stock control arms and fabricate a watts link and either a torque arm or third link setup with a ford 8.8 axle. the one issue i'm concerned about is that the forward mount is a vertical bolt going up into the floor with rubber bushings. I figure i can switch to a spherical bearing for that though. So what im trying to gather is opinions and experience on the three link vs torque arm for adjustability and stability in different types of turns, like long fast sweepers or tight autocross type course. Also what software people have had success with in the real world after designing their own setups. This is a budget build, i sell mercedes parts as a side business so most of the parts i will use come from newer and massive mercedes sedans. The engine and 13" four piston front brakes come from a 92 500sel. The rears are slightly smaller but i may just stick with the mustang brakes that come with the 8.8, since it has c-clip axles and the mercedes has non floating two piston calipers which can cause issues with kicking the pistons back into the calipers with the movement allowed by c clips.
