      May 2017
      Canada
      1967 camaro pro touring value
      67 RS CamaroEngine:
      LS364
      Horsepower: 446 @ 6200 rpm
      Torque: 412 @ 5000 rpm
      Compression Ratio: 10.9:1*
      Bore x stoke (in): 4.00 x 3.62
      Block: Cast Aluminum 6-Bolt main, cross bolted main caps
      Crankshaft: Nodular Iron. Powdered metal rods
      Heads, Chamber size: Aluminum, Symmetrical Port
      Pistons: Flat top cast aluminum
      Valves: 2.000 intake/1.550 exhaust
      Camshaft, Lift: 0.500 intake/0.500 exhaust, Hydraulic roller
      Camshaft Duration @ 0.050 in: 200 intake/203 exhaust*
      Rocker arm ratio: 1.7:1
      Maximum rpm: 6000
      Intake Manifold: LS1 4-barrel
      Carburetor: Holley Double Pumper Vacuum-Secondary 750cfm
      Holley 97 GPH RED electric fuel pump
      Clutch: Centerforce Dual Friction & Wilwood Hydraulic kit
      Alternator: Street & Performance Serpentine Kit
      Radiator: Be Cool Polished, Dual Core, Dual electric fans
      Heater hoses: Cool Flex
      Ignition: MSD 6LS-2 Ignition Controller, MSD Multi Spark Coils, PowerMaster starter
      Transmission:
      Tremec T-56 6 speed with mechanical speedo adaptor and McLeod slik stix shifter
      Exhaust:
      Hooker Super Competition Metallic Ceramic headers, 2.5" exhaust with 40 series Flow Masters mufflers.
      Suspension:
      Hotchkis TVS system (coils, sway bars, tie rod sleeves, and leaf springs)
      Hotchkis Tubular Upper and Lower A-Arms
      QA1 Stocker Star Single Adjustable Shocks
      Sub Frame Connectors
      Brakes Front/Rear:
      Baer Claw Track
      13" cross-drilled, slotted
      Baer proportioning valve
      Wheels and Tires:
      Front: Torque Thrust II 17x7.*
      BFG G-Force 235/40R17
      Rear: Torque Thrust II 17x8
      BFG G-Force 255/45R17
      Interior:
      Restored original state except;
      Auto Custom Carpet mats, Custom Autosound Stereo
      2007 Specs:
      Curb weight: 3338 lbs
      Horsepower: Dyno'd @ 455
      Atlanta GA
      Hows the paint and body?
      was it restored?.. that would determine if you got a 60K car.
      the itty bitty TT2s hurt the value tho.. becuase that much HP and no meat.
      Id guess unrestored which the list makes it look like a stock car/ stock interior/ with just a hot LS swap, 6 speed and big brakes id guess about 40/45K.
      May 2017
      Canada
      Was a rotisserie restoration about 7 years ago no rust paint is about 7ish ill post some pics soon just on the road
      May 2017
      Canada
Size:  248.0 KBName:  20170723_005006.jpg
Size:  282.1 KBName:  20170723_005041.jpg
Size:  277.9 KBName:  20170723_005130.jpg
Size:  298.5 KBName:  20170723_005102.jpg
      Mountain Springs, Texas
      Damn, look at those brake lines and heater hoses. I hope the rest of the build quality is better. Steam vents are not connected. PCV plumbing looks sketchy. No EFI and no AC. Around $30k?
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Atlanta GA
      yup... thats no 60...
      id say max 45.. min 35.
      Dec 2008
      Detroit
      I don't know about those HP specs either. That's a relatively mild cam and no mention of aftermarket heads.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      May 2017
      Canada
      Thx everyone for input cost 36k usd
