    Results 1 to 1 of 1
      Jan 2016
      1967 Camaro (pro touring)
      1967 Camaro for Sale.
      To start off this car is not a show could but could be, I drive it weekly, I race it and autocross it. so it does have flaws.
      Body-
      Rust free all new metal when I restore it in 2014.
      Mini tub with DSE tubs.
      Paint is cyber grey metallic 7 out of 10
      All trim powder coated Satin black
      Smooth firewall
      Suspension
      TCI engineering sub frame with Single adjustable ridetech coilovers(550lbs springs)
      TCI Engineering Subframe connectors
      TCI Engineering Rear Torque arm setup with Single Adjustable ridetech Coilovers (300lbs Springs)
      Shorten Currie 9 inch with Tru trac 31 spline center section (3:89 Gear)
      Have a 2 400lbs spring and 2 250lbs springs as well (10inch)
      Brakes
      Wilwood master cylinder with stock disk to disk proportion valve
      Wilwood Front and rear disk brake 12 inch Slotted and drilled with 4 piston caliper black
      Extra front and rear rotors and 1 set of pads
      Drivetrain
      LS1(out of a 99 trans am) with Fast 92mm intake and throttle body and 36lbs. injectors.
      Does have arp rod bolts.
      Magnum T56 close ratio
      Wilwood Slave cylinder
      Custom cut driveline
      Pypes violator 2.5inch Exhaust turn down before the rearend
      Headers from TCI engineering
      Interior
      dakota digital dash
      Stock reupholster rear seat
      Kirkey 16 inch road race seats
      Ridetech tiger cage with ridetech 5 point harnesses
      Radio with hidden antenna I use XM radio or my phone
      Wheels
      Forgeline ZX3 wheels Satin black with polish lip 18x9 front and 18x11 rear
      BFG rival S tire 275/35 front and 315/30 rear new about 200 road miles and 4 wet autocross passes
      Lights
      Turn signal, brakes lights, park lights, reverse lights all have LED Bulb, Headlights are LED for a new jeep.
      Car weighs 3200lbs with 3/4 tank of gas.
      The bad.
      No horn
      no interior dome light
      No heat or AC
      Never hooked up the door locks(it was always garage kept, they are there just never hooked up)
      Car has 10,500 miles on it
      Ill send pictures to serious buyers
      located in Kannapolis NC
      65k is the asking price.
      606-367-7613 Matt
