    Results 1 to 14 of 14
      Nov 2016
      Rockford, IL
      70 Camaro Pro Touring
      Car is no longer available.
      New Price Reduced to $32,995. Spring is coming I'm motivated to move it. Next project is in the garage.
      Rockford, Illinois
      The car came from south Georgia and previously South Carolina. Car has spent it’s life in the south and the body is straight and rust free. This car is very solid and as you can see has many quality parts. Car is sorted out and everything works as it should. I'm going another direction with my car hobby so this one needs to go. Well built car for the price.
      E-mail me at [email protected] for more pictures.
      If you want to discuss call me @ 815-312-8353
      406 SBC- original Chevy block
      9.1 compression ratio
      Lunati Rotating assembly -internal balance
      Professional Products Harmonic balancer
      Splayed main bearing caps
      AFR cylinder heads- 195
      Comp Cams Xtreme Energy Cam w/ Lift of I 502 E 510, Duration @.050 I 224 E 230, LSA 110 deg Hyd/Roller
      Cower Hyd/Roller Lifers & 1:7 rockers
      MSD Distributor
      Aluminum water pump
      Power Master High torque starter
      Edelbrock Air gap intake with new Demon cfm carburetor
      Black wrinkle valve covers
      New K&N filter setup
      BeCool Aluminum radiator with dual electric fans
      3" Stainless exhaust , Magnaflows dumped in front of rear axle
      DynaTech headers
      LT1 /T56 Transmission
      Mcleod billet flywheel with clutch & pressure plate
      DSE power steering pump w/ remote reservoir
      Hydraulic clutch
      Custom Aluminum driveshaft
      Ford 9" from Strange, Moser 4.11 gear center section with Posi, 35 spline axles
      Ricks Stainless Sumped tank, Aeromotive A1000 with 10 and 100 micron filters
      All black braided -10 to carb, -8 return
      No A/C or Heat
      Mini tubbed
      Subframe is connected and welded with 3x4 tubing all the way to back bumper, basically a full frame car now
      Wilwood 4 piston brakes with Wilwood master cylinder
      Original split bumper
      Complete AAW wiring kit
      Anvil Auto Carbon Fiber parts:
      -Power Bulge hood
      -Deck lid
      -Center Spoiler section
      -dash panel
      -filler panel
      -core support closeout
      -Front inner fenders
      -tail lights
      Fesler:
      -Hood Hinges
      -strikers
      -halogen head lights
      -jamb vents
      -core support braces
      -Hood adjusters
      new door handles
      All chrome fits great
      INTERIOR:
      new carpet
      billet shifter with black leather boot
      4 point harness
      Aftermarket seats from Summit, front rear covered in custom leather
      4 point cage installed when I got it. All attachment points are plated and welded
      new door handles and trim plates
      Carbon dash panel with Autometer Speedo, tach, oil, water temp, volt, oil temp
      New dash pad, New sun visors
      Dash is complete with all the original vents
      Momo steering wheel with billet adaptor
      Tilt column
      Pioneer CD, (2) 6" 3 way in the doors, and (2) 6x9 in rear package tray, 200 watt amp
      Power Windows , switches under headlight knob
      Remote battery in pass trunk, with main shutoff switch
      Suspension
      BMR upper and lower front arms
      BMR rear torque arm, with welded brackets on rear end
      AFCO remote reservoir triple adjustable shocks setup
      BMR watts link
      BMR trans X-member
      Tires and wheel
      Formula 43 RAD S5's
      18x9 front with 255/35 18
      18x12 rear 335/30 18
      Toyo R888’s
      Mike
      I'm old, gray hair, balding, and retired, and I'm still wrenching on cars. I thought wisdom came with old age.
      70 Camaro, 406 sb, 6spd, 4:10 gear, BMR Suspension
      Nov 2016
      Rockford, IL
      Delete
      Mike
      that's a shame, you haven't had it very long. GLWTS
      Nov 2016
      Rockford, IL
      New pictures added. Heading a new direction so it needs to move.
      Mike
      Sep 2011
      Southern Ontario
      That looks like a great deal. Good luck with the sale
      Nov 2016
      Rockford, IL
      Still available. Motivated seller.
      Mike
      Nov 2016
      Rockford, IL
      This is a very good car for the money. Still available and I'd like to move it before winter. Lets talk.
      Mike
      Nov 2016
      Rockford, IL
      Bump
      Mike
      Nov 2016
      Rockford, IL
      Bump with price reduction.
      Mike
      Feb 2014
      Wow, that's a SUPER nice car. Great price too!
      Nov 2016
      Rockford, IL
      Bump
      Nov 2016
      Rockford, IL
      Note new price reduction. Next project is in the garage.
      Mike
      Jan 2012
      Indianapolis, Indiana
      its a shame you dont want to trade i have a 07 z06 with 55k on it and a lingenfelter top end (3500mi on top end) made 6XXna on a mustang dyno
      your car is amazing, close to where i wanna end up with my next car to cruise and have a blast in
      Nov 2016
      Rockford, IL
      Car is no longer available. Trying different marketing approach.
      Mike
