    Results 1 to 13 of 13
    Thread: LSA Fuel System
      Jan 2007
      CT
      The stock ZL1 is a single pump style. If you check out the camaro5 forum and the zl1 sub forum everyone is upgrading the fuel system with a BAP or something at the 650 mark. The CTS-V is a duel pump which uses a Dw300 style pump (2 of them) and can support roughly 750hp (crank). I have not heard of any vaporworx issues and I've been checking out every LSA build i can find. The vaporworks controller basically ties into the stock subharness and adds fuel. Way easier to use than modifying a stock system.
      The stock LSA injectors are good for about 10% overdrive pulley with headers depending on the tune. Most upgrade to the FIC, ID, other aftermarket injectors.
      My LSA swap will use the CTS-V module, Vaporworks pwm with corner pickups, and the ricks tank.
      X2 on talking with Carl he knows this stuff inside and out and is super nice.
      Nick
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
