    Results 41 to 60 of 83
    1. #41
      Jonesboro, Arkansas
      This is going to be a pretty cool project. I like the looks of this model truck. Really looks like your headed in the right direction, can't wait to see the finished product.
      Carl Wilson
    2. #42
      Jul 2013
      St. George, UT
      Thanks Carl!
      A couple more shots of the custom sheet metal work and the LED taillight cutouts. Coming up on the to do list: final body work and chassis assembly gets started. Stay tuned!
    3. #43
      Jul 2013
      St. George, UT
      Sheet metal updates- getting the engine bay knocked out...
    4. #44
      Jul 2013
      St. George, UT
      First stages of the push button gas cap cover mod...
    5. #45
      Jul 2013
      St. George, UT
      Moving into the door mods we're installing one piece glass to eliminate the wing windows and part of the process is filling the gap where the wing window frame was. Once the door was gutted we found it to be quite flimsy, so while we were fixing up this top area we also built some support structure inside each door. We're also using Kindigit flush door handles and got the inner structures TIG welded in. Just a little more sheet metal work left and then on to finish body work.
    6. #46
      Sep 2013
      sw Kansas
      Coming along nicely. Did you mention the color layout?
    7. #47
      Jul 2013
      St. George, UT
      Thanks wfo. Did you mean the final paint scheme?
    8. #48
      Sep 2013
      sw Kansas
      Yes. I'm old and have little memory so if it was posted earlier, I apologize.
    9. #49
      Jul 2013
      St. George, UT
      No worries, I think many of us are at that point. Wait, what were we talking about? ...Lol!
    10. #50
      Jul 2013
      St. George, UT
      The cab is getting close to starting the finish body work, meanwhile the bed has been hammered and dollied and had a slight skim coat of metal glaze run over the surface, and then is sanded to perfection. The bed is almost done, and the next step will be to bed line the underside.
    11. #51
      Jul 2013
      St. George, UT
      Body work is rolling along, the bed and fenders are done with smoothing the panels and are in epoxy awaiting primer and block sanding, while the cab is now in the body booth. Final paint and assembly is starting to appear as a light at the end of the tunnel, and we're all excited to see things progressing towards that.
    12. #52
      Jun 2012
      South Lyon, MI
      Ben,
      I like the design. It is modern, but not so much that it loses its classic lines.
      I need to hire you to draw my Nova in its full slammed road race trim. I want to keep hints at its true heritage, but make it a real open road contender.
    13. #53
      Jul 2013
      St. George, UT
      Thanks for the compliments Bill!
    14. #54
      Jul 2013
      St. George, UT
      Even though this was a new fender it still takes some effort to get that sheetmetal perfectly straight. A skim coat and block sanding does the trick and will help accentuate the truck's flowing lines and BMW blue hue. Door handle pockets for the Kindigit flush handles are near finished too.
    15. #55
      Aug 2011
      Granite City
      That's ashame you have to invest that much effort into a new part to make it nice.
    16. #56
      Apr 2011
      Nice job! What gauge sheet metal are you using for the firewall/engine compartment?
    17. #57
      Aug 2014
      Quote Originally Posted by Ben@SpeedTech View Post
      Is that Roman in the background?
      Jay
    18. #58
      Jul 2013
      St. George, UT
      Lol! Kinda looks like him right? No, that's actually Bob our lead Paint and Body man.
    19. #59
      Great design, are you still putting the vents in the hood?
    20. #60
      Jul 2013
      St. George, UT
      Yes Wayne, but after trying to deal with inner structure and hinge placement rather then cut up the hood they'll be made from billet and mainly a visual enhancement.
      Metal straightening and main body work is complete, a coat of epoxy primer has been laid down and the fine body work commences!
