      May 2016
      Cadillac, MI
      Rear ports in rpm air gap
      Are the rear ports in my RPM air gap intake suitable for sending units for the temperature sensor on my fast ez-efi? I see they are not crossovers so I'm worried about it being stagnant water not getting in the correct temperature?
      Southern Indiana
      It should work fine, might read a tad slow but should work fine. See if engine cools quickly that area may take slight amount more time to adjust but it would work fine.
      Lee Abel
      AFTERMARKET PERFORMANCE
      I have always had the same question, my concern was if you just put a sending unit in the port is there enough water movement to read accurately.
      Just curious.
      Tom
      Oct 2016
      Hello, I had a sending unit on the rear port of an rpm air gap to control an electric fan, I think there is enought water movement to read the temp accuratly but it will read an hotter temp vs the front port, about 30-40°F hotter.
      Nov 2016
      Rockford, IL
      I've wondered as well. What if you make a crossover line from bank to bank and put a sender fitting in it. I'm not sure what the flow pattern is in the heads but it should move side to side just like the front does.
      Just my random thoughts.
      Mike
      I'm old, gray hair, balding, and retired, and I'm still wrenching on cars. I thought wisdom came with old age.
      70 Camaro, 406 sb, 6spd, 4:10 gear, BMR Suspension
