      Jan 2017
      Davis, CA
      Buick Distributor suggestions for EFI?
      Does anyone know if it's possible to convert a '73 Buick distributer to a small cap HEI?
      I have a modified stock distributor in the car that will work with the TBI system I'm considering (Holley Terminator), but the ECU wouldn't be able to control spark.
      Chris
      Oct 2006
      NJ
      I've done a locked out MSD version and used an MSD box (no module required). I've also converted the magnetic to hall effect for a less noise prone setup which also worked well. I'm sure a factory distributor could be reworked with a little time.
      Dennis
      Moore Racecraft
      Dec 2008
      Connecticut
      Quote Originally Posted by davisca455 View Post
      Does anyone know if it's possible to convert a '73 Buick distributor to a small cap HEI?
      Forget the small cap GM HEI computer controlled ignition module. Run an MSD CD ignition box instead.
      You can use a Hall-Effect "geartooth" type sensor (LINK) without installing any magnets.
      The Hall-Effect crank sensor is wired as shown in the Holley EFI Wiring Manual:
      http://documents.holley.com/techlibr...10555rev17.pdf (Holley EFI Wiring Manual - Figure 11, Page 20)
      http://forums.holley.com/showthread....m-Sensor-Setup (Crank & Cam Sensor Setup)
      http://forums.holley.com/showthread....ing-Holley-EFI (Ignition Timing Synchronization)
      May God's Grace Bless You
      '78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, 4" lift, 35" tires
      Jan 2017
      Davis, CA
      Thanks for the help Dennis and Danny.
      Much appreciated,
      Chris
