Results 21 to 28 of 28
11-19-2005 #21
Let me ask this. Since the car is going to be without paint for a while and I still hope to drive it, would it be ok if I spray the car in DP90, drive it around in the elements. Then, when it is time to do the paint, strip it all off and do what Jim suggested?
Will it protect the bare metal from the elements in the short term?
11-19-2005 #22I have been reading an article (series) by Larry Lyles out of Amarillo TX. and has said that PPG has changed their procedure's on rust protection to a 3 step process. It is going to bare metal and doing and hammer and dolly work, but not plastic then covering the car, panel etc. in PPG DP74LF epoxy primer in 2 wet coats w/ 10-15 minutes between them. Allow 24 Hrs to cure and then scuff w/180 grit to apply plastic at this time. if you go back to bare metal while working the plastic you have to recover it W/ the DP74LF. It mixes 2.1 with DP402LF catalyst. If anybody wants a copy of the article I can email it to them.
1980 Z/28 383, Vortec heads, 2004R 342.1 powertrac
1971 Firebird on rotisserie
2006 Dodge Daytona Charger
"Torred" # 1988 of 2000
2013 Hot Wheels Edition 2 SS Camaro
"I'm Not a Gynecologist, but I'll Take a Look"
11-19-2005 #23
