    Results 1 to 3 of 3
    Thread: 1969 Chevelle
      Feb 2015
      1969 Chevelle
      Price: 32k
      New Body and Trim Parts:
      Under carriage with raptor bed liner
      Front fenders
      SS Hood, with new chrome SS Grills
      Ring Bros. hood pins
      Header Panel
      Front bumper valance
      Front core support
      T3 headlights
      Grill, and chrome pieces
      Headlight eye brows
      Chrome bumper
      Front turn signals
      Metal wheel wells *Not installed
      Rear Chrome bumper
      Rear Chrome tail panel upper and lower pieces
      Tail light lenses
      Chrome taillight bezels
      Trunk lock, door locks,
      Windshield
      Windshield Trim (3 piece)
      Rear window trim
      Rear window
      Chrome side marker bezels
      New door handles
      New trunk
      New Interior items:
      Floor board tunnel is custom and raised for max space
      Front and rear door panels, Black in color
      Corbeau Seats
      Crow 5 point harnesses with cam lock style
      Roll cage constructed of .120 wall, 1-3/4" DOM built by a shop. Cage was built for max room.
      The cage extends up into the bracing which was trimmed so the bar could extend high up in the roof line. The catch ties into the frame, extends through to the trunk and also up to the engine compartment.
      OE style pads with Drive by wire pedal.
      Ducth Boy's shifter
      Dash pad, trimmed to fit down bars of cage
      Autometer 3-3/8" Tach and speedo with 2-1/16" Fuel, oil, volt and water gauges These are mounted in a Covan Classic dash
      Lokar park brake lever with Ironworks mounting pad
      Car has B-Quiet style sound insulation, Ididit tilt column
      Drivetrain:
      LS3 Crate Long block, has L76 intake, 517 RWHP/497 Torque
      Speartech E67 ECM with harness, LS2 MAF,GM 02 sensors, Has Corvette accessories, Alternator was a rebuilt unit, Edelbrock 409 SS Headers
      ATS Road Race pan, Remote Oil Filter with -12 Lines
      Griffin radiator with dual Spal Fans, Flywheel Mcleod Series 100 clutch and pressure plate
      Ram hydraulic throw out bearing with tilton remote res.
      TKO600 5 Speed, .64 ratio
      Classic Motorsports Group LSX style alum bell housing.
      Inland Empire driveline, 3-1/2" Aluminum with 1350 u-joints
      Currie 9" rear end with black powder coat
      31 spline axles with ½" ARP studs
      Cats Ion third memder with True Trac posi.
      3.50 rear gear
      Torino/LB style.
      Rick's stainless steel EFI gas tank with 255 walborough in tank pump
      Using Vette FPR
      Suspension:
      Front Upper controls made by SPC Performance
      Lower control arms made by SPC Performance
      Front coil over conversion ridetech single adjustable with 650# spring rate
      ATS/AFX spindles with C5/C6 hubs, with ½" ARP studs
      7/8" solid front sway bar.
      All tie rods, and mving parts are new.
      ATS/Lee 600 Steering box,
      Rearend control arms Upper and Lower made by Currie enterprise, Johnnie Joint stle
      ridetech single adjustable rear coil overs
      Brakes:
      Kore 3 / C6 Front calipers
      13" Baer 2 piece rotors front and back, Eradispeed
      Rear calipers are Baer/Vette style Track plus style #136-4262065
      Baer proportion valve
      New brake lines
      Wilwood Dual master cylinder, (Manual brakes)
      Wheels and Tires:
      Fikse Profil 13, 3 piece wheels
      Rear wheel 18 x 11"
      Rear tire 295/35/18 NT05 Nitto tires
      Front wheel 18" x 9-1/2" front tire 275/40/18
      I have a full catalog of receipts.
      Jun 2017
      bump sweet build
      Feb 2015
      Sold
