    Results 1 to 20 of 27
      Jul 2016
      Battery cable through firewall options
      Are you guys using a bulkhead connector at the firewall to run the positive battery cable through or just a grommet ?? I'm not sure I like the idea of a LIVE cable connection at firewall using a bulkhead connector. I was also considering just a grommet and run the pos cable to the starter. I hope those caps on the bulkhead connector will prevent accidental contact.
      Go to someplace like Aircraft Soruce and get cable end covers. They are like a flexible short spark plug boot to cover exposed wire terminals.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Jul 2016
      Thank you.
      Jun 2012
      CLaZoYTmktECFUQdaQodNGgO9Q
      I have used these.
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Jun 2012
      86 Mustang
      Jul 2016
      Thanks.
      Atlanta, GA
      Local Junkyard
      Here you go- a neat solution-cost maybe $5 at your local pull-a-part
      Not only to hook up your starter but also a terminal block for a couple other connections-
      Mounted on the firewall- look at the mid 90's BMWs - the big ones 5 & 7 series
      Cover on-
      Yes, I'd reconsider on the bulkhead. They are damn useful for lots of things.
      John Parsons
      Nov 2016
      Cape May County NJ
      I have used these many times with great success
      https://www.waytekwire.com/item/4721...nction-Block-/
      A mans garage is his castle.
      Feb 2011
      dallas, tx
      I used the same bulkheads as dse.
      Jul 2016
      Thanks everyone.
      Fredericksburg, VA.
      I have been running this bulkhead connector from AllStar and have been very satisfied.
      https://www.summitracing.com/parts/aaf-all76142
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Huntington Beach, CA
      I'd also consider not leaving the main battery cable live. Use a Ford solenoid or equivalent so it's live only during cranking.
      Dec 2008
      Detroit
      Quote Originally Posted by Chad-1stGen View Post
      x2 on both of these. I have the All Star Performance bulkhead and a Ford solenoid, both work great.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      El Paso, Texas
      I've used the heavy duty rubber grommets successfully. I can't remember the brand but I'll attach some links. I've used them through frames and firewalls with no problems and they've stood up well. I'll look for a brand and part number tomorrow.
      https://www.lectriclimited.com/media...und_straps.jpg
      http://www.steelerubber.com/battery-...met-40-0322-21
      Chicago
      Jul 2016
      Quote Originally Posted by 70 Chevelle View Post
      This is exactly what I will be using. Damn thing is huge though. Hope the engine is not too far back with the holley mounts and LS3.
      Jul 2016
      Quote Originally Posted by CapSS92 View Post
      The battery grommet is another option. However, I'm using 1/0 Batt cable. Actually, I think the 1/0 gauge cable is 5/8's. I will have to double check. Thx.
      Chit-ca-go
      I'm using this with no problems so far. I may switch to the bulk head since I'm redoing a few things. I currently pull power at the starter for the Speartech harness. It would clean things up just a bit if it was on the firewall.
      1971 Firebird
      2017 Slipstream SS
      Not sure why guys don't like the bulkhead. Even DSE uses them and supplies them with their battery relocation kit. Put a protective cap on it and you are good to go.
      Also curious if DSE uses a relay for the starter cable. I am pretty sure GM does not use one for the trunk mounted batteries in the 5th gen Camaros.
